Fiesta 1.25 Zetec 2001
I have a Fiesta that has been standing in the garage for about 12 months, i went to start it recently after charging the battery as it was flat but the car would not fire.There is no priming sound from the fuel pump when the ignition is switched on so i swopped the fuel pump relay and checked the fuse.The inertia switch was also ok but still no noise from the pump.Can anyone tell me how to check if there is any supply to the pump.Any help would be much appreciated.Thank you.
Remove block connector off fuel pump and check for a live with ignition on
Do you have to drop the fuel tank to do this
No should be able get under seat
