Fiesta Remote Locking Key Replacement
I've just bought a 2003 Fiesta Zetec with no remote key just the spare key although whenever i get in the dash light flashes for what i think is the alarm. Do i need a remote key to stop this? if so do i need to go to ford for this?
Any help is appreciated as the flashing and clicking is driving me insane.
The flashing light is the immobiliser indicator which should go off once a key with a coded transponder is turned in the ignition.
If you enter your reg or vin here it should tell you whether your car came with remote locking or not-
https://www.etis.ford.com/vehicleRegSelector.do;jsessionid=C382D6F0CFB743CBE2C83D1FA4F66E98.fcvas504
If yes then you can get a remote key cut and coded but Ford will rob you.
I'd recommend scouring ebay for a new key complete with transponder chip, circuitry and an uncut blade and then find a good local Auto Locksmith to set it up for you.
If your car doesn't have RCL then I still recommend a second non-remote key for spare just in case.
If you lose your current key then recovery companies call out locksmiths on an emergency shout and that can cost upwards of £300.
