smd Posted March 23, 2015 Share Posted March 23, 2015 Hi All, First time posting on here. Hopefully I am posting in the right area otherwise kindly point me in the right direction. I think the part I am looking for is a right hand rear door mould which goes across the rear door and then across the front door like a little bumper. Mine has started to peel away and bent and when I drive on the motorway I can here it flapping. I have a ford fiesta zetec blue 08 plate and the mould is blue too. Do you know if this is a mark 6 and also where do you think I can purchase this part from? I have tried Ford but they are very expensive. Many thanks Quote Link to comment Share on other sites More sharing options...
MarksST Posted March 23, 2015 Share Posted March 23, 2015 If it's still complete and in good condition, gently peel it off and refix it with new double sided foam tape. Quote Link to comment Share on other sites More sharing options...
smd Posted March 23, 2015 Author Share Posted March 23, 2015 Hi marksst. Unfortunately it's not in good condition anymore. I should have done that straight away. Quote Link to comment Share on other sites More sharing options...
MarksST Posted March 23, 2015 Share Posted March 23, 2015 You could try breakers yards but they may not be in good condition. Try Fordpartsuk, they're genuine parts usually a bit cheaper then the dealers, they would need painting though. Failing that remove them all for a cleaner look. Yours sounds like a late MK6 ( also known as a MK6.5 or prefacelift) as I don't think the MK7 had bump strips. Quote Link to comment Share on other sites More sharing options...
