gpaterson92 Posted August 16, 2015 Share Posted August 16, 2015 I was wondering if anyone knew if it is possible to use a bluefin Superchip on two separate fiestas of the exact same model? I'm wanting to install the chip on my MK7.5 and my mates about to get the same car on Monday. Just wondered if we can split the cost and both get the install? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 16, 2015 Share Posted August 16, 2015 It doesn't work that way. In order to put the map onto your car it has to be swapped over with your original configuration. If you plugged it into your mates car all that would be on the unit is your original boggo standard set up. Superchips isn't daft enough to make it that easy for you. 5 Quote Link to comment Share on other sites More sharing options...
gpaterson92 Posted August 16, 2015 Author Share Posted August 16, 2015 Damn! Thanks for clearing that up though Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
M4RC Posted August 16, 2015 Share Posted August 16, 2015 It doesn't work that way. In order to put the map onto your car it has to be swapped over with your original configuration. If you plugged it into your mates car all that would be on the unit is your original boggo standard set up. Superchips isn't daft enough to make it that easy for you. I'm sure that is what happens but bluefin can reset it for £100? Just means one of you's couldn't go back to standard Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted August 16, 2015 Share Posted August 16, 2015 It can't be done Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 16, 2015 Share Posted August 16, 2015 They will only reset a handset if you send them back the modified map, which means you must put your original one back on the car. Quote Link to comment Share on other sites More sharing options...
L22EEW Posted August 16, 2015 Share Posted August 16, 2015 Crafty !! Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 16, 2015 Share Posted August 16, 2015 Crafty !!Anything other than that method wouldn't be good business. Quote Link to comment Share on other sites More sharing options...
