Thomas Frederiksen Posted January 27, 2016 Share Posted January 27, 2016 When i press the rear fog light button, nothing happens. The bulb is ok, so I'm suspecting a faulty relay, occasionally I hear a short buzzing sound when pushing the button, but not near enough to identify it further. I have browsed through forums, manuals, asked my way around - but haven't been able to find any information or diagrams showing the position of the relay. Can anyone here point me in a direction? S-max 2008 TDCi Thanks in advance Thomas (Denmark) Quote Link to comment Share on other sites More sharing options...
iantt Posted January 27, 2016 Share Posted January 27, 2016 Simple answer is it hasnt got a relay as such, its controlled by the body control module, (fusebox assy)does the fog lamp warning light iluminate? Quote Link to comment Share on other sites More sharing options...
Thomas Frederiksen Posted January 27, 2016 Author Share Posted January 27, 2016 Yes, the dashboard fog light warning shows its on. I was just assuming there was a relay of some sort since the front fog light (that works) clearly indicates on/off via a clicking sound.. Quote Link to comment Share on other sites More sharing options...
fastvelz Posted March 24, 2016 Share Posted March 24, 2016 Try reset the bcm by pulling it's power (located under glove compartment) you will need your radio code after. May otherwise be a shorting prob Quote Link to comment Share on other sites More sharing options...
