Central Locking
nipstar
 Share
Hi Guys,
I am having a problem with my central locking on my car and was hoping someone on here could help.
When I press the lock button it will lock the doors and then unlock straight away. The unlock button works on all doors and boot apart from the drivers door I need to unlock it with the key. I know it's only a small problem but it get annoying. If any one can help will be much appreciated.
Cheers John :)
Link to comment
Hi John, I had a similar problem on my Citroen Xm which turned out to be the door locked switch, and I found it by disconnecting each door harness in turn by unscrewing the door harness connector until I found the one which didn't unlock when the remote was pressed, dismantling the door card to get to the door lock connections I disconnected the connecters until I found the connecter which controlled the door locked switch and as it was integrated into the mechanism I simply left the switch disconnected until I could replace the lock mechanism.
Norman
Link to comment
If it locks and unlocks using the key in the drivers door, the drivers door lock motor not worknig. Replace the drivers side motor asm.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
