naomi richardson Posted May 5, 2016 Share Posted May 5, 2016 Hi, having recently purchased a used ford ka titanium 62 plate i am after some advice re auto start stop please. When i am waiting in traffic the message reads 'stop start unavailable'. I am aware certain conditions are required for the function to work and having read what they are in the handbook i have tried to ensure these conditions are met (eg no AC on, wipers not on, engine right temp etc) but message still comes up and function does not work. Does this imply an underlying problem? Thanks. Quote Link to comment Share on other sites More sharing options...
iantt Posted May 5, 2016 Share Posted May 5, 2016 when it says unavailable, normally it indicates an engine fault rather than stop start conditions are not met. 1 Quote Link to comment Share on other sites More sharing options...
naomi richardson Posted May 5, 2016 Author Share Posted May 5, 2016 Ok, thanks Ian. Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted May 15, 2016 Share Posted May 15, 2016 As above, if stop start can't work because the conditions aren't met it just won't stop. It'll idle ad usual with no dash lights etc until the conditions are met and it stops. The only time I've ever had stop start say unavailable is when I stopped outside my unit, removed my seatbelt & opened my door. The car obviously knew I wasn't in the car and displayed a warning to switch off the ignition :) www.yorkshiredetailing.co.uk - approved resellers of the Highest quality detailing & Valeting supplies 1 Quote Link to comment Share on other sites More sharing options...
Crizza Posted January 29, 2020 Share Posted January 29, 2020 Auto stop start won’t work if battery charge is below 75 percent this happened to me and I went to my garage and they checked the battery condition, this was the first check recommended by ford. A new battery put things right. My old battery was 5years old so I was okay with that my auto stop starts is now working perfectly. If this happens to you you could always try charging your battery first.😎 Quote Link to comment Share on other sites More sharing options...
