focus mk2 1.6 zetec 55 plate petrol manual clutch problem ?
kory1986
 Share
lads please help
my focus mk 2 is making a wired noise at the biting point of my clutch bit like a tapping or machine gun sound its not overly loud but its there also every time i pull of in first gear the car is juddering like pulling off in a higher gear if i take it easy when pulling off its not as bad also my biting point is now higher than before car feels like its vibrating more two clutch is vibrating as well . i have just changed the rear gear box mount which helped with the gear change as it was lose is it the clutch or the fly wheel
Link to comment
most likely youre slave cylinders gone either way its a gearbox out replace the whole clutch time clutch and slave cylinder
Link to comment
is that including the fly wheel m8  is the slave cylinder part of the clutch assembly or is it a separate part
Link to comment
just been on one of those sights where you put your job on the internet for garages to compete on your work i asked the garage if the fly wheel needed replacing they said no as my car has a solid one and not a dual mass one is it true that solid ones dont need replacing also saw this on a number of web-sights saying the same thing
Link to comment
I had my clucth changed and have also solid flywheel. They did unmount it and resurfaced it but the same one was used again.
Link to comment
it turned out to be the clutch release plate there was some metal peeling off or something
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
