Baggiejames Posted November 23, 2016 Share Posted November 23, 2016 Hi all I'd like to change my audio unit from the standard one to the Sony piano black version. Is it a case of just switching the units around or is there any other work involved? Thanks in adavnce Quote Link to comment Share on other sites More sharing options...
iantt Posted November 23, 2016 Share Posted November 23, 2016 pretty much plug and play as long as you get the same age of display as yours is( needs to be compatable with either bluetooth or sync as applicable to your car) and the audio unit has dab or not depending on your existing set up. the expert on the forum with identifying part numbers and compatability is@jw1982 . 1 Quote Link to comment Share on other sites More sharing options...
Baggiejames Posted November 23, 2016 Author Share Posted November 23, 2016 thanks for the advice hopefully all goes well Quote Link to comment Share on other sites More sharing options...
JW1982 Posted November 24, 2016 Share Posted November 24, 2016 The Sony audio system is only compatible with the High Level audio system. The High Level audio system has a 10 digit keypad and is always combined with either Bluetooth/Voicecontrol or SYNC 1.0/1.1. The Sony audio system is not compatible with the Low Level audio system. The Low Level audio system has a 6 digit keypad and no bluetooth functionality. The Low Level audio system has different/less wiring than the High Level and Sony audio systems. Next to this the Sony audio system wull only be compatible if it is based on the same system as the car. A 2011 Focus MK3 High Level audio system is based on the old Bluetooth/Voicecontrol system. In this case the Sony audio system must also be based on the old Bluetooth/Voicecontrol system. If the Sony is based on the newer SYNC 1.0/1.1 system it will not work correctly. Full compatibility can only be determined by comparing/checking the part numbers and its specifications in the Ford Ecat parts system. 2 Quote Link to comment Share on other sites More sharing options...
Baggiejames Posted November 29, 2016 Author Share Posted November 29, 2016 Thanks for the advice might just leave it as it is, sounds to complicated for me. But again thanks for the help and advice Quote Link to comment Share on other sites More sharing options...
