Le Fanz Posted December 1, 2016 Share Posted December 1, 2016 Hi chaps, since installing my drl's ive always wanted to replace my standard bulb head lights with xenom ones just because the go better together. I know the MK2.5 ST has xenom headlights so I'm just thinking I could replace my current ones with these but just want to see if yous have any thoughts on it? im driving a 2010 Zetec S. Thanks Steven Quote Link to comment Share on other sites More sharing options...
WES180 Posted December 1, 2016 Share Posted December 1, 2016 Hi Steven. If you put Fitting Xenon into the search bar above it brings up loads of posts about this and the legalities of doing the conversion. Quote Link to comment Share on other sites More sharing options...
Le Fanz Posted December 2, 2016 Author Share Posted December 2, 2016 On 01/12/2016 at 7:51 AM, WES180 said: Hi Steven. If you put Fitting Xenon into the search bar above it brings up loads of posts about this and the legalities of doing the conversion. Awesome thanks for the reply Quote Link to comment Share on other sites More sharing options...
TangoDaz Posted December 2, 2016 Share Posted December 2, 2016 Take a look at your loom where it plugs into the light unit. If you have ten wires then you should be okay but if not you may have trouble I didn't have all ten so ended up using the dipped beam feed to power the ballast via a relay. A tutorial is on YouTube Quote Link to comment Share on other sites More sharing options...
btmaldon Posted December 2, 2016 Share Posted December 2, 2016 You will also require the headlamp washers and the auto light leveling system to go with the Xenons to be road legal and insurable. 2 Quote Link to comment Share on other sites More sharing options...
