Paddy94 Posted May 5, 2017 Share Posted May 5, 2017 Hey guys. Leaving my car in to get the timing belt and water pump done next week and I'm wanting to get the main drive belt done as well. My car has aircon, so i think it has two different belts? The air con belt looks almost new but the main belt (Alternator, water pump, etc) is looking a bit worse for wear. What I'm wondering is, is it possible to just change the one belt? Or will I need to change both? Also, I've been looking at belts on eurocarparts and was wondering if this one would fit? http://www.eurocarparts.com/ecp/c/Ford_Focus_1.6_2005/p/car-parts/belts-chains-and-tensioners/engine-parts/car-drive-belt/?202777285&1&0d3d200c076dbb0a8307066a2f3f98037cabac16&000108 Thanks. Quote Link to comment Share on other sites More sharing options...
Albert27 Posted May 5, 2017 Share Posted May 5, 2017 49 minutes ago, Paddy94 said: Hey guys. Leaving my car in to get the timing belt and water pump done next week and I'm wanting to get the main drive belt done as well. My car has aircon, so i think it has two different belts? The air con belt looks almost new but the main belt (Alternator, water pump, etc) is looking a bit worse for wear. What I'm wondering is, is it possible to just change the one belt? Or will I need to change both? Also, I've been looking at belts on eurocarparts and was wondering if this one would fit? http://www.eurocarparts.com/ecp/c/Ford_Focus_1.6_2005/p/car-parts/belts-chains-and-tensioners/engine-parts/car-drive-belt/?202777285&1&0d3d200c076dbb0a8307066a2f3f98037cabac16&000108 Thanks. There are two separate belts on my diesel focus. One is the timing belt and the most important belt to change because if it snaps you'll likely end up with a damaged engine. The second belt is the auxilliary belt or Drive belt that runs round the alternator and air con etc.. Some garages will change the drive belt at the same time as they have to take it off to get access to the timing belt but best to check with them if you wanted it changed. The interval for the drive belt change on my focus is 125,000 or 10 years I think. Hope that helps. Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted May 6, 2017 Share Posted May 6, 2017 11 hours ago, Albert27 said: There are two separate belts on my diesel focus. One is the timing belt and the most important belt to change because if it snaps you'll likely end up with a damaged engine. The second belt is the auxilliary belt or Drive belt that runs round the alternator and air con etc.. Some garages will change the drive belt at the same time as they have to take it off to get access to the timing belt but best to check with them if you wanted it changed. The interval for the drive belt change on my focus is 125,000 or 10 years I think. Hope that helps. He Might have a 1.6 Petrol, I don't know what the configuration for the aircon and alternator is for that. I wouldn't recommend leaving your timing belt to 125k tho, I changed mine about 75, the close to 125 you get the move chance it can go wrong, not sure its something I would want to take any chances on tbh! Since you need to take the aux belt(s) off to get the timing belt sorted, then it seems daft not to change them at the same time, but do you need to? nope 2 Quote Link to comment Share on other sites More sharing options...
JW1982 Posted May 6, 2017 Share Posted May 6, 2017 The 1.6 Duratec Petrol engine has 2 different drive belts. The 1st drive belt drives the water pump and the alternator and the 2nd drive belt drives the airconditioning pump. Both belts are stretch belts without tensioners. Stretch belts can officially only be installed once (however there are ways to reuse them). Ford prescribes to remove the belts by cutting them. Personally I would not even bother to reuse the stretch belts. The stretch belts are pretty inexpensive and reusing them will void any warranty on the timing belt change. If a stretch belt snaps it potentionally can cut the timing belt cover and timing belt which will cause serious engine damage. 1 Quote Link to comment Share on other sites More sharing options...
Albert27 Posted May 6, 2017 Share Posted May 6, 2017 3 hours ago, Dee_82 said: I wouldn't recommend leaving your timing belt to 125k tho, I changed mine about 75, the close to 125 you get the move chance it can go wrong Haynes reckon about that too, i think it's 62500 in the book. I got mine done around the 80k mark and just in time according to the mechanic. Quote Link to comment Share on other sites More sharing options...
LuvSardine Posted September 18, 2017 Share Posted September 18, 2017 how do i adjust the belt circled in red in this picture? Quote Link to comment Share on other sites More sharing options...
isetta Posted September 18, 2017 Share Posted September 18, 2017 i don't think you can. as said in posts above it is a stretch belt. it is installed with a special guide that feeds belt on to pulleys as you turn them. and it is removed by cutting off. 1 Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted September 18, 2017 Share Posted September 18, 2017 Is the 1.6 petrol a 16v then? I know little really but looks like dohc from that pic? Quote Link to comment Share on other sites More sharing options...
iantt Posted September 18, 2017 Share Posted September 18, 2017 you cant, streatchy belt. Quote Link to comment Share on other sites More sharing options...
JW1982 Posted September 18, 2017 Share Posted September 18, 2017 If the stretch belt is slipping it needs to be replaced. Quote Link to comment Share on other sites More sharing options...
biff55 Posted September 18, 2017 Share Posted September 18, 2017 rumour has it that iantt uses an alternator stretch belt to hold up his pants........ 1 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted September 18, 2017 Share Posted September 18, 2017 rumour has it that iantt uses an alternator stretch belt to hold up his pants........ nope, there round my ankles all the time. lol 1 1 Quote Link to comment Share on other sites More sharing options...
biff55 Posted September 19, 2017 Share Posted September 19, 2017 Hey , could anyone point out the waterpump position in this photo ? i have the same engine and need to keep an eye on a shoddy dealership repair lol Quote Link to comment Share on other sites More sharing options...
stef123 Posted September 19, 2017 Share Posted September 19, 2017 13 hours ago, biff55 said: rumour has it that iantt uses an alternator stretch belt to hold up his pants........ Do they do them that big? Lol 2 Quote Link to comment Share on other sites More sharing options...
stef123 Posted September 19, 2017 Share Posted September 19, 2017 2 minutes ago, biff55 said: Hey , could anyone point out the waterpump position in this photo , i've got a shoddy dealership repair i need to keep an eye on lol Just under the engine mount, to the right. Flat pulley with 4 bolts. 1 Quote Link to comment Share on other sites More sharing options...
LuvSardine Posted September 19, 2017 Share Posted September 19, 2017 Thank you guys for the confirmation. I figured it was a stretch belt from deep research and a whole day staring under the hood looking at the engine to find an adjuster lool 1 Quote Link to comment Share on other sites More sharing options...
Micro Posted September 20, 2017 Share Posted September 20, 2017 A little on topic, useful with the engine picture. Where would you support the engine from underneath whilst replacing the right engine mount? The haynes manual just refers to using a jack with a block of wood but does not specify where is safe to do this. I also notice there is a position for an engine crane? on the top left which I can probably borrow for 10 minutes whilst at work if it would be more suitable to support the engine (and the advantage of not having to remove the engine undershield!). Quote Link to comment Share on other sites More sharing options...
stef123 Posted September 20, 2017 Share Posted September 20, 2017 under the sump with a block of wood to spread the load is the usual place. Quote Link to comment Share on other sites More sharing options...
Chicinel Posted September 18, 2019 Share Posted September 18, 2019 Hi guys my two little belts flew from their tracks how can i put them back on? The ones that need cut when replacing. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted September 19, 2019 Share Posted September 19, 2019 12 hours ago, Chicinel said: Hi guys my two little belts flew from their tracks how can i put them back on? The ones that need cut when replacing. How did that happen? There must be a problem with one of the pulleys? You can put them on with a thin screwdriver if you don't want to buy the proper tool. Just put the screwdriver across the pulley and slowly/carefully turn the pulley at the same time as gently pushing the belt on. Obviously being careful not to stick the screwdriver through the belt lol. 1 Quote Link to comment Share on other sites More sharing options...
JW1982 Posted September 19, 2019 Share Posted September 19, 2019 And most important watch your fingers. I can tell from experience that getting stuck between the belt and the pully while slowly turning the pully does not feel very nice. 2 Quote Link to comment Share on other sites More sharing options...
Tomo140792 Posted February 1, 2021 Share Posted February 1, 2021 Hi, is there anyway of deleting AC on my fiesta 1.6tdci.. or does the belt have to run around the AC pulley ? Thanks Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 2, 2021 Share Posted February 2, 2021 10 hours ago, Tomo140792 said: Hi, is there anyway of deleting AC on my fiesta 1.6tdci.. or does the belt have to run around the AC pulley ? Thanks You'd have to remove the spring tensioner, but as long as it clears the engine mount you should be OK with it just around the crank and alternator. You may find less contact patch around the alternator though. Quote Link to comment Share on other sites More sharing options...
Tomo140792 Posted February 2, 2021 Share Posted February 2, 2021 2 hours ago, TomsFocus said: You'd have to remove the spring tensioner, but as long as it clears the engine mount you should be OK with it just around the crank and alternator. You may find less contact patch around the alternator though. Okay thanks , would I need a shorter belt or can I use the existing one? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 2, 2021 Share Posted February 2, 2021 54 minutes ago, Tomo140792 said: Okay thanks , would I need a shorter belt or can I use the existing one? You'd need a much shorter belt. Quote Link to comment Share on other sites More sharing options...
