melb100 Posted June 17, 2017 Share Posted June 17, 2017 Hi for about 2 weeks now, I have been experiencing sudden cutting out of my TDCI, which takes ages to start again. I get no prior symptoms, it just cuts out, however I have noticed the glow plug light flashing after it cuts out. So I turn the ignition off and try to start the engine again, and while it is cranking over and over the glow plug light starts flashing again and will remain flashing while I crank the engine over. So to explain further, when I got the car last year I noticed it had the Black coloured Cam sensor fitted, so bought the grey coloured one and fitted that, and it all seemed ok. I have read different web pages and some point to possibly the Crank sensor causing the cut out issues, but I would like to see if there is any help or advice on here. I have ordered a code reader and await its delivery, so that my throw up further possibilities for this issue? Thanks in advance for any help etc. Quote Link to comment Share on other sites More sharing options...
melb100 Posted July 4, 2017 Author Share Posted July 4, 2017 AN update: Hi, I have had a scan tool attached to read any stored dtc codes, and there are 5 as follows P1000--System readiness test not complete P2263--- Turbo charger Boost pressure/performance problem P0201--Injector malfunction P0202--Injector malfunction P0203--Injector malfunction So do these errors have something to do with it cutting out and very difficult to start afterwards? Any advice would be appreciated, thanks Quote Link to comment Share on other sites More sharing options...
