What’s wrong with my car?
Car : Ford Fiesta Ztec Climate 1.242, 2005 reg.
So this is the only issue so far, when discovered I turned the car home and parked it.
- struggles to pick up speed, sluggish.
(Cannot exceed 30mph in 3/4gear, or total max 38mph in 5th gear.)
- engine light flashes on and off.
My thoughts from reading Dr. Google are:
Spark plugs?
The box thing the plugs connect into?
If anyone can help I’d be really grateful, as my whole life unfortunately depends on this car.
You need to get the codes read there are code readers on feabay could be the catalytic converter has broken up
and the car is bogging down
Thanks for commenting, do you know if the AA carry code readers?
Yes they do but they are cheap enough on the bay
On my fairly uneducated exhaust inspection. I’ve noticed the back box has this ... could that cause this issue?f13f9976f8e747571b348133f558bf46.jpg
normally if its the cat but you will be renewing that part as its naff
Well looking at the back box i'd say theirs a good chance the baffles inside have collapsed causing a partial blockage preventing the engine from releasing the exhaust gases properly but shouldn't affect it enough to cause a limp home mode scenario unless like Dezwez says the issue is down to a partial blockage on the cat as that usually affects the signal from the o2 sensors to the ecu ..
