egrempoleco Posted January 5, 2018 Share Posted January 5, 2018 In the process of cleaning the MAF sensor in my 63-plate Ford Focus 1.6 TDCi (115), I dropped one of the mounting screws into the engine bay. Does the screw have a specific technical designation that I can use in order to source a replacement? I've attached a photo of where the missing screw should live (highlighted in red); in the photo, I've highlighted in green the twin screw (bolt?). Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 5, 2018 Share Posted January 5, 2018 The bolts aren't available seperately from Ford, they are part of the MAF kit which is is about £200. Quote Link to comment Share on other sites More sharing options...
egrempoleco Posted January 8, 2018 Author Share Posted January 8, 2018 Stoney, Thanks for the response. Is there any way of seeing what makes up a MAF kit, that you know of? Something like a parts list? Basically, I'm hoping that Ford reuse the same parts (i.e. the screws here) for efficiency purposes; if I can get a technical designation or description for it, I can search around. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 9, 2018 Share Posted January 9, 2018 The Ford parts system (Microcat) does not show the bolts as seperate items and therefore no size information is available.3 options-1, go to Ford and pay through the nose for a full maf kit.2, take out the remaining bolt and get some hardware shop to match a replacement one up.3, go to a scrappy with a screwdriver and scrounge one out of a scrapped car (most Ford models and many Volvo's use the same maf so bolts should match). Sent from my SM-G930F using Tapatalk Quote Link to comment Share on other sites More sharing options...
