Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
translating
2369 replies to this topic
#1666 Preee
Preee
    Ford Fruitcake
  • 4,099 posts
  • Name: Paul
  • Ford Model: Focus Tit X Mk3 | Fiesta Zetec Mk7
  • Year: 2012
Posted 09 November 2013 - 10:49 PM
I'm lookings at both programs , as i have been speaking to a Russian guy that has enabled the center screen on his Mk3 Focus to accept a standard PAL input for a reverse camera with out Ford's £600 worth of modues , and he said he flashed the screen via software , so i was checking if either UCDS or ADS was the program , but neither mention it. So i guess i will have to wait for him to respond with what he flashed the screen with.
Thanks for the Links Mayak:)
Have something to contribute?
#1667 liam-20
liam-20
  • Budding Enthusiast
  • 149 posts
  • Name: liam
  • Ford Model: focus st3
Posted 10 November 2013 - 10:44 AM
hey guys need sum quick help I can get accress to everything except the 3rd menu on the hec it just keep coming up with warning say frw.dat file missing had look in file and it is there am I doing anything wrong?
#1668 Preee
Preee
    Ford Fruitcake
  • 4,099 posts
  • Name: Paul
  • Year: 2012
Posted 10 November 2013 - 04:20 PM
Liam its the folder structure you must have it can't find the firmware file. if you go back a few pages on this guide i told Dezwez how to do it.
#1669 saklak
saklak
    Member
  • PipPip
  • 27 posts
  • Name: Marius
  • Ford Model: Focus MK2 Ti-VCT
  • Year: 2005
Posted 10 November 2013 - 06:22 PM
Not sure if this is the right place but since is connected with Elm327 I'll go ahead :).
Using Forscan and having all that live data ( dashboard ) how do you know which
numbers are correct and which not ? are you watching for spikes or something ?
Totally noob here ...
#1670 dezwez
dezwez
    Dezwez
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 4,743 posts
  • Name: Derek
  • Ford Model: ford focus 1.8 zetec mk 2.5
Posted 10 November 2013 - 06:56 PM
post is on page 108 at the botom
#1671 mayak
mayak
  • 72 posts
  • Name: Marcin
  • Ford Model: Focus mk 2
  • Year: 2007
Posted 13 November 2013 - 10:35 AM
latest version of ELMConfig (11c) supports Bosch PCMs in FF2, so 1.6 tdci and ST but it has beta status - has anyone tried to enable cruise control in 1.6 tdci ?
#1672 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 19,470 posts
  • Name: James
  • Year: 2007
Posted 13 November 2013 - 01:27 PM
might need to give it a go! I havent tried it yet, I am still on v11a maybe b though...
Same download location as the original post by Preee?
#1673 mayak
mayak
  • 72 posts
  • Name: Marcin
  • Year: 2007
Posted 13 November 2013 - 01:40 PM
there is no 11a - there was 11, 11b and 11c
all 'elevens' are almost the same
link as always: http://civil.iffc.ru...g/ELMConfig.zip
#1674 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 19,470 posts
  • Name: James
  • Year: 2007
Posted 13 November 2013 - 01:56 PM
I guess its b I am using lol
#1675 clubber
clubber
  • 109 posts
  • Ford Model: ST3
Posted 13 November 2013 - 07:40 PM
I've tried it on an ST but there is no READ/WRITE VID block in the Procedures>Page 2 so you can't write the modified PCMDump to the car
See this post
http://www.fordowner...c-max/?p=304791
#1676 mayak
mayak
  • 72 posts
  • Name: Marcin
  • Year: 2007
Posted 13 November 2013 - 10:49 PM
to activate cruise control in Bosch PCM you don;t need to write whole firmware - just read VID-block, tick integrated-something and then write VID-block
that's all
#1677 clubber
clubber
  • 109 posts
  • Ford Model: ST3
Posted 14 November 2013 - 08:27 AM
to activate cruise control in Bosch PCM you don;t need to write whole firmware - just read VID-block, tick integrated-something and then all
There's no option to "read VID-BLOCK" in elm config. The only option is to "Read the firmware from PCM to BIN file" and "Load firmware from PHF/BIN file". I have done both of these (also ticked integrated speed control), when it finishes writing it comes up with an error that says invalid request (or something similar) . I'll try it again when I get home and put up a screen shot.
#1678 mayak
mayak
  • 72 posts
  • Name: Marcin
  • Year: 2007
Posted 14 November 2013 - 08:33 AM
in version 11, read/write (separate write of vid-block works only for 1.6tdci) of vid-block is in configuration!!!!!!!
1. PCM -> Configuration -> Read from PCM
2. save to file (as a back up)
3. tick 'Integrated Speed Control'
4. PCM -> Configuration -> Write to PCM
5. done
#1679 clubber
clubber
  • 109 posts
  • Ford Model: ST3
Posted 14 November 2013 - 08:46 AM
Will it also work on the 2.5 ST?
#1680 clubber
clubber
  • 109 posts
  • Ford Model: ST3
Posted 14 November 2013 - 03:47 PM
5. done
I have done this and get the "Writing VID-block completed" confirmation
Cruise still doesn't work.
The car can detect the buttons as they all play a sound when I use the rear heater switch "trick"
For some reason I can't add pictures so I can't upload the screenshot of ELMconfig
I'm pressing ON the + to activate cruise on the steering wheel buttons. Is there a minimum speed before cruise works?
Not what you're looking for?
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
