Jimmyb Posted February 6, 2015 Share Posted February 6, 2015 My 2008 Ford Focus 1.6 SI has this electrical fault that electricians cannot help me with. The problem is resolved when they reset error codes etc, but returns randomly. Currently my car has been sitting at my finacee's work with this problem. Please view the info below and advise if any of you know the possible cause or have had a simular problem. The car runs fine, but the central locking will suddenly not work when leaving the car. I put the key back into the ignition and the following faults appear; Speedo guage shoots up to max speed and stays there. Rev counter needle moves up and down. Engine temp is at max. Doors will lock and unlock repeatedly. Roof light comes on and off. Strange buzzing noise is heard from the passenger side consol. Car does not turn over / start. I would appreciate your assistance in solving this mystery. Rgds Jim Quote Link to comment Share on other sites More sharing options...
stef123 Posted February 6, 2015 Share Posted February 6, 2015 Has anyone checked the connectors under the dash where the fusebox is? They are known to cause problems when disturbed/kicked Quote Link to comment Share on other sites More sharing options...
iantt Posted February 6, 2015 Share Posted February 6, 2015 As stef said, check fusebox, have you had pollen filter done recently, there is a bunch of wires that can trap behind fusebox bracket, causing all sorts of electrical issues. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 6, 2015 Share Posted February 6, 2015 certainly seems like an electrical fault, check all fuse boxes for water ingress. Quote Link to comment Share on other sites More sharing options...
