PLB Posted May 19, 2019 Share Posted May 19, 2019 The Information Display in my 4 month old Mk4 focus has just started showing the following information. l This error has also caused the following audio issues with my Sync 3.3 No Touchscreen Beeps No Sync 3 Voice Request or Confirmation Prompts. No Sat Nav turn Information Prompts or confirmation beeps. No Phone Receive Audio or Text Read out Audio I have carried out a Sync 3 factory reset but problems are still present. I will arrange for my dealer to take a look ASAP, but has anyone else experienced this problem or have any ideas as to what it’s likely to be. Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted May 19, 2019 Share Posted May 19, 2019 Not seen that before, I would try removing the fuse in the first instance, or disconnect the battery for 5 mins. The code is built into the APIM\BCM so it will reset itself fine. To quote the IT crowd "Have you tried turning it off and on again" 1 1 Quote Link to comment Share on other sites More sharing options...
pragmatix Posted May 19, 2019 Share Posted May 19, 2019 23 minutes ago, Jonro2009 said: Not seen that before, I would try removing the fuse in the first instance, or disconnect the battery for 5 mins. The code is built into the APIM\BCM so it will reset itself fine. To quote the IT crowd "Have you tried turning it off and on again" A master reset may work just as well Quote Link to comment Share on other sites More sharing options...
PLB Posted May 19, 2019 Author Share Posted May 19, 2019 1 hour ago, pragmatix said: A master reset may work just as well Thanks, but if you mean a sync 3 master/factory reset I have tried that but it made no difference. To honest I don't think it’s a Sync 3 problem but I may be wrong. Quote Link to comment Share on other sites More sharing options...
pragmatix Posted May 19, 2019 Share Posted May 19, 2019 12 minutes ago, PLB said: Thanks, but if you mean a sync 3 master/factory reset I have tried that but it made no difference. To honest I don't think it’s a Sync 3 problem but I may be wrong. What version of thecsoft ware are you on,? 3.3 is the latest i believe. Have a look here. https://www.ford.co.uk/owner/resources-and-support/sync-bluetooth/update#/ Quote Link to comment Share on other sites More sharing options...
PLB Posted May 19, 2019 Author Share Posted May 19, 2019 36 minutes ago, pragmatix said: What version of thecsoft ware are you on,? 3.3 is the latest i believe. Have a look here. https://www.ford.co.uk/owner/resources-and-support/sync-bluetooth/update#/ I am on 3.3, Build 18351 which I believe is the latest. Quote Link to comment Share on other sites More sharing options...
ianincheshire Posted May 20, 2019 Share Posted May 20, 2019 Version 3.3 Build 19052 is available on the Sync update site as of this morning 1 Quote Link to comment Share on other sites More sharing options...
PLB Posted May 20, 2019 Author Share Posted May 20, 2019 OK, the latest. My car has been parked on my drive for most of yesterday and overnight. Just got into the car this morning and the error message is not showing and everything appears to be back to normal.👍 Looks like it must have somehow reset itself some time yesterday or overnight. I wonder if there is a form self-checking/housekeeping that goes on in the background when the car is parked. BTW, I have automatic updates disabled. Strange. Quote Link to comment Share on other sites More sharing options...
PLB Posted May 20, 2019 Author Share Posted May 20, 2019 1 hour ago, ianincheshire said: Version 3.3 Build 19052 is available on the Sync update site as of this morning Thanks for the information. Yes, I have just checked and it looks like its available for me to. I will check it out later. Quote Link to comment Share on other sites More sharing options...
Freeze Posted May 21, 2019 Share Posted May 21, 2019 I've been maintaining a list of confirmed bugs / recalls etc. in a Finnish Ford forum for the new Focus Mk4. It's a known bug in car software. Have the module software upgraded at your dealership. 2 Quote Link to comment Share on other sites More sharing options...
Quigzz Posted July 22, 2019 Share Posted July 22, 2019 On 5/20/2019 at 11:42 AM, PLB said: Thanks for the information. Yes, I have just checked and it looks like its available for me to. I will check it out later. Did you get this issue sorted? I'm having the same issue, I took it to Evan's halshaw a month ago. They claim the part is on back order but I'm guessing they dont actually know what it is. I've had software updates which didn't fix it. Quote Link to comment Share on other sites More sharing options...
iantt Posted July 22, 2019 Share Posted July 22, 2019 If it's just the message showing, it's probably the emergency call button internal failure, they are on back order quite often . 1 Quote Link to comment Share on other sites More sharing options...
PLB Posted July 22, 2019 Author Share Posted July 22, 2019 1 hour ago, Quigzz said: Did you get this issue sorted? I'm having the same issue, I took it to Evan's halshaw a month ago. They claim the part is on back order but I'm guessing they dont actually know what it is. I've had software updates which didn't fix it. I have only had the problem show a couple of times since new but on each occasion it has mysteriously cleared itself overnight as explained in my previous post dated May 20th. In your case is the message below showing every time you start your vehicle. Apart from the message above does the emergency call button permanently glow bright red. (Normally it should initially glow bright red and then dim.) Do you also get the following audio problems. No Touchscreen Beeps No Sync 3 Voice Request or Confirmation Prompts. No Sat Nav turn Information Prompts or confirmation beeps. No Phone Receive Audio or Text Read out audio. If you get the error message and also get the above audio problems (as I did) I stand to be corrected but I doubt it would be the emergency call button. What part have they on back order? Also, please let us know how things go as I may be just lucky that the issue has temporary gone away for me but I would like to know if there is an official fix. Quote Link to comment Share on other sites More sharing options...
DP93 Posted July 23, 2019 Share Posted July 23, 2019 got mine booked in for thursday as I have had this error twice, only had my focus for 3 weeks. It goes but taking it in anyway to see if a reset or something will help. Did you get anywhere with yours? I've also had the sync3 freeze on me to a point that I couldnt change anything unless using the steering wheel so I wonder if this is related? Appreciate the post about its a known bug, will bring this up when I see them. If this is the case then I guess it will be sorted via a F/W update. Quote Link to comment Share on other sites More sharing options...
DP93 Posted July 23, 2019 Share Posted July 23, 2019 On 5/21/2019 at 8:47 AM, Freeze said: I've been maintaining a list of confirmed bugs / recalls etc. in a Finnish Ford forum for the new Focus Mk4. It's a known bug in car software. Have the module software upgraded at your dealership. Freeze, do you happen to have a link or something to the error list. I will show them this thread when I go on Thursday. Thanks Quote Link to comment Share on other sites More sharing options...
Quigzz Posted August 14, 2019 Share Posted August 14, 2019 On 7/22/2019 at 9:00 PM, Quigzz said: Did you get this issue sorted? I'm having the same issue, I took it to Evan's halshaw a month ago. They claim the part is on back order but I'm guessing they dont actually know what it is. I've had software updates which didn't fix it. I've just received my car back from Evans Halshaw, they had it for 3 days to fit the part which was on back order. I'm sure it was a telematics sensor. 1 Quote Link to comment Share on other sites More sharing options...
PLB Posted August 15, 2019 Author Share Posted August 15, 2019 On 8/14/2019 at 7:09 PM, Quigzz said: I've just received my car back from Evans Halshaw, they had it for 3 days to fit the part which was on back order. I'm sure it was a telematics sensor. Thanks for the update. Fortunately, or may be luckily I haven’t had the problem with the 'Emergency Call System' error message showing for a while now. I am taking my car in next week so my dealer can investigate my 'Keyless Entry' problem and the 'Auto Stop Start' not working but I am expecting them to say it’s down to the battery. I may question them regarding the intermittent ‘Emergency Call System’ error message and if they are aware of a possible telematics sensor problem.👍 Quote Link to comment Share on other sites More sharing options...
Yorkshire Phil Posted August 22, 2019 Share Posted August 22, 2019 I had this problem on mine. I picked it up in April and within a month the call malfunction appeared. It disappeared overnight but then came back again a couple of weeks later and was permanent with all the faults mentioned in previous posts. At the same time there was fault with the drivers door mirror not always folding fully back when locking it. I took it to Lookers and they told me it needed a new telematics unit. This took 2 months to come and they also recalibrated the door mirror. Ive had no problems since (touch wood). It looks like it could be a common fault. 1 Quote Link to comment Share on other sites More sharing options...
mweaver01 Posted August 28, 2019 Share Posted August 28, 2019 On 8/14/2019 at 7:09 PM, Quigzz said: I've just received my car back from Evans Halshaw, they had it for 3 days to fit the part which was on back order. I'm sure it was a telematics sensor. i had this fault as mentioned in the first post a couple of weeks ago, it happened once and reset itself after 20 mins. Owned car for 4 months. 3 days is a long time to have the car, did they have to strip the dashboard out or something? and did you get a courtesy car? Thanks Quote Link to comment Share on other sites More sharing options...
Wazza43 Posted September 19, 2019 Share Posted September 19, 2019 I've had exactly the same error today with all the same symptoms. Booked into local Ford deal (TC Harrison - Burton) for next Friday. I suspect a tripped sensor or fuse issue. Quote Link to comment Share on other sites More sharing options...
Wazza43 Posted September 19, 2019 Share Posted September 19, 2019 21 minutes ago, Wazza43 said: I've had exactly the same error today with all the same symptoms. Booked into local Ford deal (TC Harrison - Burton) for next Friday. I suspect a tripped sensor or fuse issue. It's cured itself! I had the problem this morning, started and stopped the car no effect on fault. Left the car at work for hours, drove back one hour, switched off the car a couple of time, no effect. Got home, posted this and then after 30mins on the front drive, I drove to the local chippy and no fault! Quote Link to comment Share on other sites More sharing options...
Ams Posted September 19, 2019 Share Posted September 19, 2019 Could it be something wrong with this system today itself? Strangely enough I saw the same message as well. I pressed the ecall button and when it said calling emergency services in 15 secs, i pressed the button again to cancel the call. Turned the car off and left it for couple of hours. Drove again for around 25 mins and everything was fine. Quote Link to comment Share on other sites More sharing options...
jwharmsby Posted September 26, 2019 Share Posted September 26, 2019 (edited) Just for anyone else having this issue, right after I’d booked in for a service I noticed that my FordPass app wasn’t locking or unlocking the doors so I looked in settings and noticed my onboard modem serial number was missing. Tried resetting all settings etc, nothing. Tried reseating fuse to reboot modem and seems to have worked. If you’ve got this emergency call error and your modem serial is missing, remove fuse panel cover in passenger footwell, fully remove fuse 11, give it a wipe and reinsert. Fixed my error (and the FordPass app) straight away. Might be worth a try! Edited September 26, 2019 by jwharmsby Added a line Quote Link to comment Share on other sites More sharing options...
Atlasj2 Posted October 1, 2019 Share Posted October 1, 2019 On 9/26/2019 at 2:31 PM, jwharmsby said: Just for anyone else having this issue, right after I’d booked in for a service I noticed that my FordPass app wasn’t locking or unlocking the doors so I looked in settings and noticed my onboard modem serial number was missing. Tried resetting all settings etc, nothing. Tried reseating fuse to reboot modem and seems to have worked. If you’ve got this emergency call error and your modem serial is missing, remove fuse panel cover in passenger footwell, fully remove fuse 11, give it a wipe and reinsert. Fixed my error (and the FordPass app) straight away. Might be worth a try! Just got this message today but mainly noticed my front Speakers stopped working! Took your advice and Speakers back in action plus no message. Just need to keep an eye on this and why it's happening in a 3month old car. Quote Link to comment Share on other sites More sharing options...
Atlasj2 Posted October 8, 2019 Share Posted October 8, 2019 The error came back for me. Every day now I have to call emergency, cancel and I get my front Speakers back. I've just done a Sync 3 update still happens. Quote Link to comment Share on other sites More sharing options...
