Emergency Call System Malfunction.
Hi guys,
I have this issue everybody here talks about.
"Emergency call system malfunction. Service required."
Two dealers told me that the entire roof must be dissasambled in order to check the antenna. I heard that this can be fixed with an TCU module update but until now i havn't managed to figure this out yet.
I saw here that some on you fixed this by pulling the F11 out and get it back in. Can anyone show me or tell me which one is F11, because on the passanger fusebox i can't find that fuse at all, or maybe its another number on it.
Please help!
Thank you!
  • Replies 311
  • Views 372.1k
  • Had a two week break over Christmas with no driving of the focus........  on return Flat battery!!!!! ford Assist guy on the phone say that the battery will go flat over two weeks?  so my response was
  • I generally buy a 1 Yr old used car. Possibly next year I'd be due to buy. I really think I'll need to move away from Ford as fear getting one of these used bangers that someone's had issues with. Dam
  • Jonro2009
    Jonro2009
    Not seen that before, I would try removing the fuse in the first instance, or disconnect the battery for 5 mins. The code is built into the APIM\BCM so it will reset itself fine. To quote the IT
Oh, so it dosent have a 11 on it. F11 its actually 11+12 fuse ?
Apparently the automatic one is the same as the manual.
1 hour ago, robertmihai717 said:
Hi guys,
Please help!
Thank you!
My MK4 DIESEL FOCUS has sometimes the same issue.
The cause: Extreme air humidity
The cure: Nothing...it stops by itself after a few minutes and some heavy curses...
You mean, u got the same message "Emergency call system malfunction. Service required." and the cause is from extreme air humidity?
I had the message 1st time back in January and it just dissapeared like 1 month almost, but now its back and idk what should i do....
Will try F11 as i dont want to leave it to the dealer since they want to break the entire thing for one notification man :))
F11 did not worked for me at all. Will do a TCU update next week, i've heard that this solved the issue for many people there with this message.
My car was stolen and returned a few hours later with these exact problems! Sos malfunction
no voice commands being heard and calls not working properly
Is this something I can fix or garage?
1 hour ago, Laurax2aa said:
garage?
garage 👍
  • 2 months later...
Car went to the dealer's with this problem and came back with a new TCU, but still the same problem ("Emergency call malfunction").
Seems Ford is having software problems when coding new hardware to cars. My car isn't the only one with problems at my dealer's. They changed the ABS at the same time and it took them five weeks (!) to get it coded to my vehicle. And they couldn't code the TCU at all.
  • 1 year later...
I believe there is a back up battery don't know where it is
Ford garage job.
  • 1 year later...
I've seen these info.
"The TCU has a small internal backup battery (like a rechargeable battery). Its function is to ensure that, if you have a serious accident and the car's main battery is destroyed, the eCall system still has power to geolocate you and call emergency services. The problem: After 7 or 8 years (your car is from 2018), this internal battery usually reaches the end of its lifespan and stops holding a charge. The symptom: As soon as the TCU detects that its internal battery is depleted, it displays the exact "Emergency-call-system-malfunction" warning. Even if you update the software a thousand times, if the battery is dead, the error will persist."
I'd like to try changing the battery to try it to see if it solves the problem. If I do, I'll update here.
This good man updated a video of how to dismount the TCU
https://www.youtube.com/watch?v=uIXVxX2IGf0
