How to fit a multi colour warning LED driving signal strip
Hi all,
First post here, I've had a browse for a similar thread but haven't come across one yet so forgive me if I duplicate a post.
My Car -  Focus S Eco-boost 1ltr 2015
Picked up the following product: 1.2m 12v Car trunk multi colour warning light flow driving signal LED strip.
My issue is I don't know how to wire it, what wire from the LED strip goes to which wire leading to the light cluster, I've removed the drivers side rear light cluster easily and have reasonable access to the wiring from both within the boot and at the back of the cluster and I'm fairly comfortable with securing the cables once connected.
Just asking if anyone can dumb it down for me as to how exactly to wire it in 🙂 Image attached of the LED Tail box lamp controller with the wires on.
Would really appreciate some direction on this please 🙂
Rich
Does this help? found as the description, show more, on this site:-
Description
Condition:New Voltage:DC12V Light Source:LED Brand:Unbranded Country/Region of Manufacture:China Features: 4 Colors Flowing LED Car Tail Trunk Tailgate Strip Brake Driving Signal Light * 120cm length can be used for medium models, senior models, luxury models, sedan models * Can be used as Daytime Running Lights Lights / Rear Lights / Luggage Compartment Light / Tail Lights, etc. * 100% Waterproof, durable to use * With adhesive glue at the back for easy installation * Low power consumption, energy saving, environment friendly Long lifespan, durable to use * Universal fits for all the cars * 100% Brand New and High Quality Specifications: * Light Source: LED * Light Color: White, Yellow, Red, Blue or Multi-Color (As Pictures Show) * Voltage: DC12V * Length: 120cm (Approx.) * Width: 1.5cm (Approx.) * Thickness: 0.5cm (Approx.) Wire Function and Connection: There are 7 wires for the input of controller: * Red wire for positive of the car battery, black wire for negative of the car battery * Green wire for Blue or Multi-Color light when connecting to ACC * White wire for light on highlights red when connecting to brake light * Yellow wire/L for light mode on yellow color 25% brightness from streamer from left to right * Yellow wire/R for light mode on yellow color 25% brightness from streamer from right to left * Blue wire for light on highlights white when reverse gear * Double flash warning: yellow light streamer mode from center to both sides at the same time and same speed, it is highlight red color in the middle * Light mode on red by steam when the brake and rotation function is lit at the same time Package Contents: Style1: 1 * Car Tail Light Strip Style2: 1 * Controller Box with Wires Note: The real color of the item may be slightly different from the pictures shown on website website caused by many factors such as brightness of your monitor and light brightness.
A quick search came up with this
Thanks for the replies both, the first post is the info I have which comes with the led strip, what I'm after is which wires do they connect to on the focus itself, as those wires are totally different colours, that's the part that's leaving me a little stumped. I was trying to find a google image that explained the wiring diagram for the lights to show which colour was what if you know what I mean?
On the led strip, the red and black wires are for live and neutral respectively, but on the focus lights, which of those is the live and neutral?
Edited by Rich_G
Added info
Does anyone have a wiring diagram for the 2015 Ford Focus S EcoBoost, i'm hoping that might help
Unfortunately I can't help you on this vehicle; however my reason for posting is to inform you;
If you can get your hands on a Haynes manual for your focus the wiring diagram will be in the back pages; I've created over twenty guides on the mk2.5 focus and stripped the entire interior for audio upgrade then refitted all thanks to the Haynes manual,
If nobody else can provide you with the details then the Haynes in the only answer mate.
I did try to intensely search for it but no joy seems to be only older versions so as above should be in the manual.
5 hours ago, Lenny said:
valid point actually, thanks for that!!
thanks for the effort buddy
