Mick Oliver Posted March 24, 2022 Share Posted March 24, 2022 Hi I had a remap done test drove it when after 1/2 a mile i had to stop at lights engine cut down to 2 cylinders and tried to pull away did so at 2 mph eventually got home and back to the guy doing the remap and he said let me set it back to standard He did erset it and the car was only running on 2 cyliders but remember before the remap it was running fine no miss fires so he said must have been there before you need new coilpacks on 2 of the cylinders and new spark plugs but he did not fit plugs or coil packs which now the bill is over £500 till did not run properly and the guy who did the remap said he would ike the other coil packs fitted to rule them out at my cost which I had done tried putting a new remap on it and was still not running right so if you removed the spark feed to cylinders 2 & 3 and it was no change so only running on 1 & 4 now at a loss as to what is wrong Has anyone had similar problems or some can help with a resolve PLEASE 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted March 24, 2022 Share Posted March 24, 2022 Of course you checked that the "guy" had full business liability insurance before you let him loose on your car ? Quote Link to comment Share on other sites More sharing options...
Hamster Posted March 25, 2022 Share Posted March 25, 2022 Disconnect the battery, short together the two L+N terminals. (On the Car, not the battery!) This resets all the modules to default with a no-power loop. Reconnect the battery and see it that has fixed it. If it does fix it leave it alone. If not is probably going to need a new ECU and reprogram by IDS. I see lots of failed ECU, BCM and TCM after folks try and 'Mod' them. This worked 15-20 years ago but now. Forscan is the biggest culprit. H Quote Link to comment Share on other sites More sharing options...
Mick Oliver Posted March 25, 2022 Author Share Posted March 25, 2022 16 hours ago, unofix said: Of course you checked that the "guy" had full business liability insurance before you let him loose on your car ? Yes he had insurance on his web site but when challanged on this he was saying no it only covers the actual mapping which is not what I thought it was I think that is rubbish but will have check it further now Quote Link to comment Share on other sites More sharing options...
unofix Posted March 25, 2022 Share Posted March 25, 2022 Sounds like a trip to the small claims court to me. There would be no way on earth I'd let him play about further with my car. I can understand the guy didn't break your engine on purpose, but sometimes things do go wrong, that's why he should have "liability insurance". If after he had done the remap the car had burst in to flames do you think your car insurance would pick up the bill ? Quote Link to comment Share on other sites More sharing options...
jimbojambojumbo Posted April 11, 2022 Share Posted April 11, 2022 On 3/24/2022 at 5:43 PM, Mick Oliver said: tried putting a new remap on it and was still not running right so if you removed the spark feed to cylinders 2 & 3 and it was no change so only running on 1 & 4 now at a loss as to what is wrong Has anyone had similar problems or some can help with a resolve PLEASE No need to buy new coil packs if you know cylinder 1 & 4 are firing swap those with 2 & 3 and then check to see if 1 & 4 are still firing Quote Link to comment Share on other sites More sharing options...
