froggy8 Posted April 16 Share Posted April 16 ok guys got another problem. at first it worked then wouldnt work and wouldnt work for few days till i changed one of my tail light and wierdly the door worked after that till i opened the door and closed it and now it stopped working. it hasnt worked for few weeks now and was wondering if anyone had that issue? cheers again 🙂 Quote Link to comment Share on other sites More sharing options...
StephenFord Posted April 16 Share Posted April 16 40 minutes ago, froggy8 said: ok guys got another problem. at first it worked then wouldnt work and wouldnt work for few days till i changed one of my tail light and wierdly the door worked after that till i opened the door and closed it and now it stopped working. it hasnt worked for few weeks now and was wondering if anyone had that issue? cheers again 🙂 Can you clarify, "won't work". Does the handle work?Is the handle jammed? Does it not operate with the central locking? Does it open from the outside, but not the inside? C'mon buddy, help us out here LOL 2 1 Quote Link to comment Share on other sites More sharing options...
froggy8 Posted April 16 Author Share Posted April 16 1 hour ago, StephenFord said: Can you clarify, "won't work". Does the handle work?Is the handle jammed? Does it not operate with the central locking? Does it open from the outside, but not the inside? C'mon buddy, help us out here LOL sorry mate, my bad 😄 basically theres no power to it, the electric window and central locking dont work but the handle does. Quote Link to comment Share on other sites More sharing options...
StephenFord Posted April 21 Share Posted April 21 27 minutes ago, adfeyc said: ...THOUGHTS...?? Yes, increase the dose of medication and seek medical help... 👍 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted April 21 Share Posted April 21 Spam. Blocked. 2 1 Quote Link to comment Share on other sites More sharing options...
StephenFord Posted April 21 Share Posted April 21 41 minutes ago, Stoney871 said: Spam. In that case, as well as increasing the medication, a nice portion of chips would go well too 😂 1 Quote Link to comment Share on other sites More sharing options...
froggy8 Posted April 30 Author Share Posted April 30 Ok guys, update I have managed to pry the door card off, everything seems OK but then I started wiggling the wire loom and the electric window briefly worked but how do I take the plug out? It is stick solid. Quote Link to comment Share on other sites More sharing options...
StephenFord Posted April 30 Share Posted April 30 20 minutes ago, froggy8 said: Ok guys, update I have managed to pry the door card off, everything seems OK but then I started wiggling the wire loom and the electric window briefly worked but how do I take the plug out? It is stick solid. The very fact that it worked, even momentarily, shows that power can get to the window, and the regulator is fine. Does sound like a wiring issue if a 'wiggle' got it going. Only this week I watched my mechanic unplug an electric window on my car. It seems that it simply pulled apart, I didn't notice him pressing any special locking tabs to release the connector, maybe I just didn't see it. Hopefully someone will be able to confirm what the knack is in separating the plug... 1 Quote Link to comment Share on other sites More sharing options...
froggy8 Posted April 30 Author Share Posted April 30 19 minutes ago, StephenFord said: The very fact that it worked, even momentarily, shows that power can get to the window, and the regulator is fine. Does sound like a wiring issue if a 'wiggle' got it going. Only this week I watched my mechanic unplug an electric window on my car. It seems that it simply pulled apart, I didn't notice him pressing any special locking tabs to release the connector, maybe I just didn't see it. Hopefully someone will be able to confirm what the knack is in separating the plug... Many thanks Ok, I will have another go maybe tomorrow. Its the plug that goes to the pillar from the door. Quote Link to comment Share on other sites More sharing options...
froggy8 Posted April 30 Author Share Posted April 30 24 minutes ago, StephenFord said: The very fact that it worked, even momentarily, shows that power can get to the window, and the regulator is fine. Does sound like a wiring issue if a 'wiggle' got it going. Only this week I watched my mechanic unplug an electric window on my car. It seems that it simply pulled apart, I didn't notice him pressing any special locking tabs to release the connector, maybe I just didn't see it. Hopefully someone will be able to confirm what the knack is in separating the plug... I was thinking, there's a cover over the pillar, I'm guessing if I take that off, will it show all the wiring? Quote Link to comment Share on other sites More sharing options...
froggy8 Posted May 1 Author Share Posted May 1 Ok guys I have an idea, what if I buy a set of wire loom and replace it with my faulty one,? Quote Link to comment Share on other sites More sharing options...
StephenFord Posted May 1 Share Posted May 1 2 hours ago, froggy8 said: I have an idea, what if I buy a set of wire loom and replace it with my faulty one,? Just curious, where do you think your, 'wire loom' terminates to? Quote Link to comment Share on other sites More sharing options...
froggy8 Posted May 1 Author Share Posted May 1 Sorry I don't understand. Do you mean where does the wire loom goes to? Quote Link to comment Share on other sites More sharing options...
froggy8 Posted May 1 Author Share Posted May 1 I will take pictures and show you what I have done and what I was planning to do. Quote Link to comment Share on other sites More sharing options...
froggy8 Posted May 1 Author Share Posted May 1 I was going to take the pillar cover off and see if I can see the wires clearly as you can see the plug, I can't seem to take that off. 1 Quote Link to comment Share on other sites More sharing options...
froggy8 Posted May 1 Author Share Posted May 1 As you can see, I really need help 😫 Quote Link to comment Share on other sites More sharing options...
StephenFord Posted May 1 Share Posted May 1 7 minutes ago, froggy8 said: As you can see, I really need help 😫 Yep, for a start, you can post the actual photos on the site by using the 'choose file' function LOL Those 'links' you did do nothing... 1 Quote Link to comment Share on other sites More sharing options...
froggy8 Posted May 1 Author Share Posted May 1 Il remember that fir next time lol Anyway, if I can get the plug out then how do I put it back in because the rubber thing doesn't seem to go back on? Quote Link to comment Share on other sites More sharing options...
StephenFord Posted May 1 Share Posted May 1 I'm going to pass you on to someone more sensible. Your definition of a 'plug' is totally different to what I thought was the electrical plug that powers your window! Looks like you are trying to remove the actual wiring loom and have just pulled upon the large fixing grommet. Problem with the internet, without an initial photo, you need to be very specific with language. Best of luck... 1 Quote Link to comment Share on other sites More sharing options...
froggy8 Posted May 1 Author Share Posted May 1 7 minutes ago, StephenFord said: I'm going to pass you on to someone more sensible. Your definition of a 'plug' is totally different to what I thought was the electrical plug that powers your window! Looks like you are trying to remove the actual wiring loom and have just pulled upon the large fixing grommet. Problem with the internet, without an initial photo, you need to be very specific with language. Best of luck... Many thanks for trying though mate 🙂 Quote Link to comment Share on other sites More sharing options...
froggy8 Posted May 1 Author Share Posted May 1 could anyone tell me if i have completely destroyed my plug please? Quote Link to comment Share on other sites More sharing options...
froggy8 Posted May 1 Author Share Posted May 1 Hey guys Been thinking alot in this, I'm not really sure what the best approach for this would be. I was actual thinking if the plug is completely useless then I might get this: https://www.ebay.co.uk/itm/124542881308?epid=1237046020&itmmeta=01HWT926EMKV550Z3EWZPRYP0F&hash=item1cff558e1c:g:iUUAAOSwG6tgDYu0&itmprp=enc%3AAQAJAAABAIGbfQj7a33bva1V%2FjU1M6ADINVrcUN6wNkwhMXZeQMRTWgCxACGtmMd886SbIyMaZptBqv5zjQ6dyG37ejmFE4%2BrcEBMfXWF%2BDusEUtmD7v7d9cXra2RH0h6LQFCWlfFUTw2fVmOmjLbNRH5iJxW447J5IBucxW0jAN2mqrmj8wcmsUMxAod%2BND20TC%2FlhdhEld%2FNMRv%2BGXtMOFBgTem4qXrv0BsLTKNxBMJwLr86lsa%2BIRVsU80kRn%2FzmRJAk%2FRWnfu0N6PmEGTFzaztakv3OE4oDnqIcJ%2FplOybLZ4X8%2BXeHrxzQQphKXftxXjlF4j1ATLiH8WLqrywftrzddzA4%3D|tkp%3ABk9SR7TniMnmYw But I have a feeling doing it this way would be so time consuming. Please tell me if any of you guys can come up with any ideas as I really don't want to go down this route. Many thanks 😊 Quote Link to comment Share on other sites More sharing options...
unofix Posted May 1 Share Posted May 1 Looking at the condition of your harness, I think you are going to be forced to replace it. There is strong evidence of corrosion of the wires and contacts. 1 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted May 1 Share Posted May 1 2 hours ago, froggy8 said: could anyone tell me if i have completely destroyed my plug please? It's not actually a plug. It is a though body connection (not the same thing). If you use a flat blade screwdriver you will be able to leaver out the plastic part, from the bodywork of the car. Refitting them is not perhaps the way you would expect. You need the full plastic housing removed from the car and then you fit the rubber boot over the plastic and push the whole assembly back in to the bodywork. 1 1 Quote Link to comment Share on other sites More sharing options...
StephenFord Posted May 1 Share Posted May 1 1 minute ago, unofix said: It's not actually a plug.... Therein lies the thing that led me to lead the poor guy up the garden path 🤣 2 Quote Link to comment Share on other sites More sharing options...
