Magenta Posted March 17, 2011 Share Posted March 17, 2011 Yes a little bit, but once you have got used to it you don't really notice it, just adjust how you access the handbrake Yes quite a lot. Don't be afraid to yank it open, just don't scratch the stereo fascia when forcing it open with whatever you decide to use Yes it is glued, I used Araldite. DON'T USE THE SYRINGE ONE Thanks. I've now opened it (using a cloth covered screwdriver !) to look and I am puzzled as to why Ford hid this compartment away behind a hinged cover without making proper access as you have done. OK so a small cost might be involved (but I think not) but it is a properly finished compartment, not something that is there by accident. They could even have finished it with no cover at all for simply another cubby hole. I wonder if this is how it was intended originally and someone decided to cover it for aesthetic reasons ? Quote Link to comment Share on other sites More sharing options...
Zetec S Blue Posted March 17, 2011 Share Posted March 17, 2011 Thanks! Nope not seen anyone with a vision blue interior.. I do think it would look really goo though I've only seen mine painted black and then a couple painted white I don't know the rear speaker size.. I do know how to get to them though (If it's a 3 door) That whole rear section seems to be held in place by those extended lugs with metal catches on that Ford use to keep most of the plastic trim on in the car I would suggest getting a torch out though and locating each catch before pulling The new Focus RS? I was looking at some replicas for that.. But they seemed very cheap and I was worried about the quality of them, as cheap alloys normally aren't great I am going to give the blue a bash I think it will go well as the dash is a blue colour, Yeah it is the 3-door I will try and take some photos when I get them off The RS wheels are actually good quality. My dad got a set for his transit connect van and they have been fine and carrying weight :) So in a lightweight car the would be fine. I have the wheels you have on mine and I'm not really a fan of them they are a bit small and don't fill the arch that well. People have recomended a lower but there are alot of speed bumps where I live and I dont want to take the front off :( I seen them on eBay and the seemed like a good deal Quote Link to comment Share on other sites More sharing options...
Magenta Posted March 18, 2011 Share Posted March 18, 2011 Yes it is glued, I used Araldite. DON'T USE THE SYRINGE ONE I'm a big fan of Araldite, used it hundreds of times without failure. Why not the dual syringe dispenser type ? I dispense resin & hardener on a piece of card to mix and then apply. I assume you only have a catch on one side of the cover ? Quote Link to comment Share on other sites More sharing options...
Ben... Posted March 18, 2011 Author Share Posted March 18, 2011 I used the syringe one twice to start with and after a couple of days it snapped off both times. Then used the separate tubes. And has been on about a year now Quote Link to comment Share on other sites More sharing options...
Ben... Posted March 27, 2011 Author Share Posted March 27, 2011 Summer Protection Products used: 'Tom' (Cheers Mate! Great Help!) Wheels Valet Pro - PH Neutral snow foam Bilberry Wheel Cleaner Autoglym Custom Wheel Cleaner Various Sized detailing Brushes Autoglym Tar & Bug Remover Meguiars Smooth Surface clay Kit Poorboys Wheel Sealant Meguiars Foam Pad Car Valet Pro - PH Neutral snow foam 2 Buckets Meguiars Lambs Wool Mitt Meguiars Gold Class Shampoo Large microfibre Drying Towel Meguiars Smooth Surface clay Kit Autoglym Super Resin Polish Dodo Juice Purple Haze Meguiars Foam Pads Autoglym Fast Glass Calipers Wire Brush Emery Roll LO30 Low Odour Solvent 1/2" Paint Brush Hammerite Smooth Red 3 Coats Drums Wire Brush Emery Roll LO30 Low Odour Solvent Masking Tape 3/4" Paint Brush Hammerite Hammered Black 2 Coats The Equipment ;) Calipers Quote Link to comment Share on other sites More sharing options...
Ben... Posted March 27, 2011 Author Share Posted March 27, 2011 Drums Fitted New Pads Too Quote Link to comment Share on other sites More sharing options...
Ben... Posted March 27, 2011 Author Share Posted March 27, 2011 The Results Wheels Quote Link to comment Share on other sites More sharing options...
Ben... Posted March 27, 2011 Author Share Posted March 27, 2011 The Car Quote Link to comment Share on other sites More sharing options...
Ben... Posted March 27, 2011 Author Share Posted March 27, 2011 The Hulk Quote Link to comment Share on other sites More sharing options...
Ben... Posted March 27, 2011 Author Share Posted March 27, 2011 Went For A Little Drive Quote Link to comment Share on other sites More sharing options...
iNath Posted March 27, 2011 Share Posted March 27, 2011 Even your trousers have the black/red theme going on :P Quote Link to comment Share on other sites More sharing options...
Ben... Posted March 27, 2011 Author Share Posted March 27, 2011 I do like the contrast if I'm honest! Quote Link to comment Share on other sites More sharing options...
2011fiesta Posted March 27, 2011 Share Posted March 27, 2011 The painted plastics and matching alloys look really good mate. Can I ask, when you were applying the Ford gel overlays, how long did you heat them up for? And did you just use a hair dryer or something? - Just the overlays on my all 4 of my wheels started to peel off on one side, so I had to remove them encase they came off when I was driving. Cheers Paul. Quote Link to comment Share on other sites More sharing options...
Ben... Posted March 28, 2011 Author Share Posted March 28, 2011 Cheers Paul Just heated them with a hairdryer until they were flimsy Same thing happened to me. I just glued the wheel badges on in the end Quote Link to comment Share on other sites More sharing options...
TroodoN Posted March 28, 2011 Share Posted March 28, 2011 Great job with the wheels. Looks really good Quote Link to comment Share on other sites More sharing options...
2011fiesta Posted March 28, 2011 Share Posted March 28, 2011 Cheers Paul Just heated them with a hairdryer until they were flimsy Same thing happened to me. I just glued the wheel badges on in the end ah right, glad I wasn't the only one - you use any particular type of glue, quick drying/water proof maybe? Quote Link to comment Share on other sites More sharing options...
Ben... Posted March 28, 2011 Author Share Posted March 28, 2011 Just Araldite Quote Link to comment Share on other sites More sharing options...
Jedilard Posted April 1, 2011 Share Posted April 1, 2011 Must admit I do admire the job you've done - regardless of if it my taste. Particularly to time and effort. People buy new houses and immediately make changes / decorate etc - so why not the same with a car? It's yours do what you like with it! I bought an Armster for my 60 reg Zetec S that I collected today - that's as far as my mods will go though!! Quote Link to comment Share on other sites More sharing options...
speedyuk Posted April 2, 2011 Share Posted April 2, 2011 Hi ben i like what you do to your car mat and i like your spare wheel clamp that you made to lock the 16" alloy in place you should sale them mate Quote Link to comment Share on other sites More sharing options...
Ben... Posted April 2, 2011 Author Share Posted April 2, 2011 I do on request ;) Quote Link to comment Share on other sites More sharing options...
speedyuk Posted April 3, 2011 Share Posted April 3, 2011 how much for one mate Quote Link to comment Share on other sites More sharing options...
MarkyR Posted April 4, 2011 Share Posted April 4, 2011 Hi Ben, thought I would add my, er, thoughts! :P First off, put your body away man, your looking disgustingly thin compared to me!! haha, now your car.... I frigging LOVE the black painted plastic trim in the interior, looks stunning! The wheels look cool, the roof lining - tough one that as in the photos it looks really messy and horrible but you know it isn't so it's hard to judge it? A VERY neat little idea with that cubby hole, may have to do it myself, and a very clever installation of the sunglasses holder too. Nice one mate. The leather looks good also. What you have done to the outside I can't tell I'm afraid, again due to your photos I guess? So I like your car, you've done lots of really nice little touches and then overhauled the interior, it looks really smart. Are you going to change the body work at all? I don't like the sun visors though? just looks a bit OTT? Anyway keep it up mate. Great thread. Quote Link to comment Share on other sites More sharing options...
mark t Posted April 5, 2011 Share Posted April 5, 2011 Can I ask, when you were applying the Ford gel overlays, how long did you heat them up for? And did you just use a hair dryer or something? - Just the overlays on my all 4 of my wheels started to peel off on one side, so I had to remove them encase they came off when I was driving. I put mine on while it was cold, so sat them on the radiator for a few minutes, doing one at a time, not had any trouble! Quote Link to comment Share on other sites More sharing options...
Ben... Posted April 5, 2011 Author Share Posted April 5, 2011 how much for one mate Pm'd Quote Link to comment Share on other sites More sharing options...
Ben... Posted April 5, 2011 Author Share Posted April 5, 2011 Hi Ben, thought I would add my, er, thoughts! :P First off, put your body away man, your looking disgustingly thin compared to me!! haha, now your car.... I frigging LOVE the black painted plastic trim in the interior, looks stunning! The wheels look cool, the roof lining - tough one that as in the photos it looks really messy and horrible but you know it isn't so it's hard to judge it? A VERY neat little idea with that cubby hole, may have to do it myself, and a very clever installation of the sunglasses holder too. Nice one mate. The leather looks good also. What you have done to the outside I can't tell I'm afraid, again due to your photos I guess? So I like your car, you've done lots of really nice little touches and then overhauled the interior, it looks really smart. Are you going to change the body work at all? I don't like the sun visors though? just looks a bit OTT? Anyway keep it up mate. Great thread. Haha it got very got polishing then waxing, plus the sun was out. I'm very happy with the panther black interior. I'm going to redo the headlining as I used 2 different glues. And one hasn't worked as well as the other. I didnt really know what to do with the sun visors. But as I said with the roof. It looks better in real life. I've now decided I dont like the leather pillars. So that is my next project. Quote Link to comment Share on other sites More sharing options...
