pcw Posted December 9, 2008 Share Posted December 9, 2008 having arrived home I turned the ignition off in the normal way but the car would not stop. In the end I had to stall the car and disconnect the battery. Now it will not start. Any idea's? Quote Link to comment Share on other sites More sharing options...
c-maxxer Posted December 10, 2008 Share Posted December 10, 2008 What model / engine is your car ? Diesel ? Quote Link to comment Share on other sites More sharing options...
pcw Posted December 12, 2008 Author Share Posted December 12, 2008 having arrived home I turned the ignition off in the normal way but the car would not stop. In the end I had to stall the car and disconnect the battery. Now it will not start.Any idea's? 1.8 Petrol Quote Link to comment Share on other sites More sharing options...
maccyski Posted March 17, 2009 Share Posted March 17, 2009 I had this problem!!!!!!!! Car switched off fine, then hour later the headlights wipers and radio turned on, started engine, everything reset, turned engine off, got out, locked car, then realised my engine was still running!!! Its to do with the brake lights. water had got in one of the rear brake lights (cant remember which one) and played around with the electrics. Did the engine stop when you pressed the brake pedal? Quote Link to comment Share on other sites More sharing options...
