Sara Fiesta Posted October 6, 2011 Share Posted October 6, 2011 Hi, I have started to notice a strange click or tick noise not a clonk when I come off the accelerater around the 1200 revs in gear is this normal? Sound like it come from the passenger side front? 1 Quote Link to comment Share on other sites More sharing options...
propw4sh Posted October 6, 2011 Share Posted October 6, 2011 Ha the same in a 2008 Fiesta - A single click every time the throttle was closed to a very light setting. I just put it down to a relay switching as you come off the gas. 1 Quote Link to comment Share on other sites More sharing options...
tomo2001 Posted October 6, 2011 Share Posted October 6, 2011 You got the air con running ? Quote Link to comment Share on other sites More sharing options...
Sara Fiesta Posted October 6, 2011 Author Share Posted October 6, 2011 Hi, relay yes could be, I haven't got the air con on, ive been recreating it on the way home tonight while I was crawling in traffic it's more like a tap noise like knock maybe ?? 1 Quote Link to comment Share on other sites More sharing options...
propw4sh Posted October 6, 2011 Share Posted October 6, 2011 You got the air con running ? The 'click' was always when the aircon was on. Quote Link to comment Share on other sites More sharing options...
tomo2001 Posted October 7, 2011 Share Posted October 7, 2011 Our fiesta does it only when the air con is running, something to do with the aircon clutch or relay if I remember rightly - quite normal. Quote Link to comment Share on other sites More sharing options...
Sara Fiesta Posted October 7, 2011 Author Share Posted October 7, 2011 Ok thanks 1 Quote Link to comment Share on other sites More sharing options...
ToolBox Posted October 7, 2011 Share Posted October 7, 2011 Sara, check your wheel nuts as soon as you can, a loose wheel will make a clicking noise at first then as the wheel becomes looser it turnns into more of a banging sound. Regards Brian Quote Link to comment Share on other sites More sharing options...
Sara Fiesta Posted October 7, 2011 Author Share Posted October 7, 2011 Ok will do thanks 1 Quote Link to comment Share on other sites More sharing options...
