Londonguy123 Posted April 16, 2013 Share Posted April 16, 2013 Good evening all ive got a ford focus 1.8 TDci 52plate Ghia covered 101k when i change gears its quite hard, as in if i put it in 1st its quite hard and sometimes it doesnt go into 1st and il have to double press the clutch to get it into gear, same goes with 2nd and 3rd what do you guys the problem could be? im just hoping its something minor.. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 16, 2013 Share Posted April 16, 2013 ok so its struggling to slide between gears? could be the selector linkage or could be a problem clutch. Can you sit with the car off, clutch down and change gears? 1 Quote Link to comment Share on other sites More sharing options...
Londonguy123 Posted April 16, 2013 Author Share Posted April 16, 2013 when the car is off the gears change fine no problem.. i really hope its not the clutch how can i go about checking the selector linkage Quote Link to comment Share on other sites More sharing options...
Nathan_M Posted April 17, 2013 Share Posted April 17, 2013 My fiesta is a bit like this sometimes although i was only doing short runs, since i have been going some its cleared up, i noticed mine was also related to cold weather as if the linkage cables change characreistics, perhaps its the plastic coating, i would have a look at the linkage cables first as it wont cost anything. Quote Link to comment Share on other sites More sharing options...
Londonguy123 Posted April 17, 2013 Author Share Posted April 17, 2013 how do i go about checking the linkage cable out? Quote Link to comment Share on other sites More sharing options...
isx600 Posted April 25, 2013 Share Posted April 25, 2013 I'd get the gearbox oil changed. Quote Link to comment Share on other sites More sharing options...
DanGersFord Posted April 26, 2013 Share Posted April 26, 2013 Moved to focus section Quote Link to comment Share on other sites More sharing options...
