TomsFocus Posted May 5, 2019 Author Share Posted May 5, 2019 1 hour ago, wilkinsj93 said: Hi Tom did you get to bottom of this problem mine is doing the same. I've topped up dpf fluid and reset the counter and given it long run up motorway just keeps regenerating and fans are running every time. James Hi James, It would be better to start your own thread really. Have you checked the differential pressure? Are the pressure pipes damaged? Is it possible your DPF is full of ash? What mileage is it on? Quote Link to comment Share on other sites More sharing options...
