Ianb Posted March 30, 2016 Author Share Posted March 30, 2016 If I take the egr off, can the car be manoeuvred? Just wondering if I can tinker with it, then drive it back to its parking space midway through.. Quote Link to comment Share on other sites More sharing options...
simcor Posted March 30, 2016 Share Posted March 30, 2016 I find the Mr muscle stuff works well but any oven cleaner will soak and remove all the built up carbon. Quote Link to comment Share on other sites More sharing options...
theredfox Posted March 30, 2016 Share Posted March 30, 2016 5 hours ago, Ianb said: Bit of sly product placement there haha other car forum's swear by mr muscle Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 30, 2016 Share Posted March 30, 2016 6 hours ago, Ianb said: If I take the egr off, can the car be manoeuvred? Just wondering if I can tinker with it, then drive it back to its parking space midway through.. Technically yes but it's not ideal... Basically you'll be sucking unfiltered air into the intake. Will also blow a bit of a exhaust but that's less of an issue as long as you're not breathing it in lol. It'll be in limp mode but should still run. Quote Link to comment Share on other sites More sharing options...
Ianb Posted March 30, 2016 Author Share Posted March 30, 2016 Ah ok thanks Tom, (and everyone else). Given the weather I might try and work on it at small intervals, but it'd be handy to roll it nearby when I get a chance. Won't be moving it far, not more than 50m's, so blowing exhaust won't be too much of an issue haha.. 2 Quote Link to comment Share on other sites More sharing options...
Ianb Posted April 2, 2016 Author Share Posted April 2, 2016 Do I need to remove valve and egr cooler thing? Metal cylinder? Quote Link to comment Share on other sites More sharing options...
GMX Posted April 2, 2016 Share Posted April 2, 2016 Ian this might be some use. I've just scanned these relevant pages from my Haynes Manual. Albeit with some difficulty, as the manual is too thick for my scanner. As a result the EGR cooler pdf is upside down, as that was the only way to fit the manual in the scanner.for that page. EGR cooler.pdf EGR removal.pdf Quote Link to comment Share on other sites More sharing options...
Ianb Posted April 2, 2016 Author Share Posted April 2, 2016 Thanks Ghana, on my phone atm, at shop looking for Mr muscle >.> removed the egr valve but not cylinder, so far... Quote Link to comment Share on other sites More sharing options...
iantt Posted April 2, 2016 Share Posted April 2, 2016 if your not blanking , and just cleaning, then you will need to remove cooler as well to make sure thats not blocked up with carbon too. Quote Link to comment Share on other sites More sharing options...
Ianb Posted April 2, 2016 Author Share Posted April 2, 2016 Ah OK, well I'll leave it in place then :) Quote Link to comment Share on other sites More sharing options...
Ianb Posted April 2, 2016 Author Share Posted April 2, 2016 Btw, after spraying with Mr muscle, how do I clean it out? Damp cloth then let dry? Or can I run some warm water through it? :s Quote Link to comment Share on other sites More sharing options...
theredfox Posted April 2, 2016 Share Posted April 2, 2016 no don't put water near it Quote Link to comment Share on other sites More sharing options...
simcor Posted April 2, 2016 Share Posted April 2, 2016 No issue running water through it in my book. That's how I did mine just make sure it is fully dry once done. We already know it is seized anyway so won't do any more harm. Just my opinion of course. Quote Link to comment Share on other sites More sharing options...
Ianb Posted April 2, 2016 Author Share Posted April 2, 2016 okiii, didn't put water in it, but does the Mr Muscle just disappear? I've tried sticking fingers in and wiping as best I could, but it's bit too fiddly for most fingers.. Quote Link to comment Share on other sites More sharing options...
Ianb Posted April 2, 2016 Author Share Posted April 2, 2016 Hmmm, two opposite views... need an informed tie breaker? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted April 2, 2016 Share Posted April 2, 2016 The issue will be getting EGR crud all over the sink...it literally gets everywhere... Scrape the stuff out with a small screwdriver or similar. Water wont damage it but you'd be better off running something like petrol through which strips it clean and evaporates quickly. Quote Link to comment Share on other sites More sharing options...
Christiancollins7 Posted April 2, 2016 Share Posted April 2, 2016 i need help please Quote Link to comment Share on other sites More sharing options...
simcor Posted April 2, 2016 Share Posted April 2, 2016 In fact failing petrol either carb cleaner, brake cleaner or surgical spirit as its alcohol and they will all evaporate quickly. 1 Quote Link to comment Share on other sites More sharing options...
Ianb Posted April 2, 2016 Author Share Posted April 2, 2016 hmmm, wonder if the garage would mind me sticking the nozzle into it on the forecourt 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted April 2, 2016 Share Posted April 2, 2016 I take it you don't have a can laying around for a petrol mower then? On the subject of garage though... I wonder if a local repair garage would clean it in their paraffin parts washer for you for a tenner or something? If not, any of Simons suggestions are fine. Carb cleaner comes in a can under about 500psi of pressure so is good for blasting stuff clean! Quote Link to comment Share on other sites More sharing options...
Ianb Posted April 2, 2016 Author Share Posted April 2, 2016 I've actually got a compressed air can, that could help clear out any loose muck. As for a mower can...haven't got a lawn let alone a mower .... https://en.wikipedia.org/wiki/Plymouth_Hoe My lawn... 1 Quote Link to comment Share on other sites More sharing options...
GMX Posted April 2, 2016 Share Posted April 2, 2016 39 minutes ago, simcor said: In fact failing petrol either carb cleaner, brake cleaner or surgical spirit as its alcohol and they will all evaporate quickly. Laser printer paper path cleaner, which iso-propyl alcohol is another good one 1 Quote Link to comment Share on other sites More sharing options...
Ianb Posted April 3, 2016 Author Share Posted April 3, 2016 Sooooo would methylated spirit or white spirit be ok? Quote Link to comment Share on other sites More sharing options...
simcor Posted April 3, 2016 Share Posted April 3, 2016 Both should be fine will evaporate pretty quickly meths will evaporate quicker though and should not cause any harm. Quote Link to comment Share on other sites More sharing options...
Ianb Posted April 7, 2016 Author Share Posted April 7, 2016 I'm going to hunt you all down and urinate on you in your sleep! I've just spent countless hours under the bonnet trying to get at those RIDICULOUS Clic clips!!!!! I MEAN MY LORD WHY WOULD ANYONE DESIGN THEM! One at one end of the egr cooler, (the furthest from the valve) took about umm idk, 1-2 hours of struggling to get on, the other end is still not on, I gave up, my tool bag isn't deep enough to find something small enough with enough guts to squeeze it shut!, I ended up leaving it unclipped and cable tying round it to keep it from getting lost - the egr unit/valve whatever the **** it's called was put back on, gasket, blanking plate..... low and behold: P0490 - Exhaust gas recirculation control circuit high P042F - EGR control stuck closed So I dunno what to do... I reset the codes, ran it for a bit, turned it off, turned it on... checked codes... reappeared etc... So tempted to stick a jar of petrol inside and light a fuse! So shattered, shaved knuckled, aching and still result not achieved! Quote Link to comment Share on other sites More sharing options...
