crossie2709 Posted February 11, 2017 Share Posted February 11, 2017 Need some help ive got some mist washer jets fitted on my mk2.5 focus had them one for a year or so and last few days they not been working properly its just dripping out PS ive filled the washer bottle up [emoji1360] Quote Link to comment Share on other sites More sharing options...
Albert27 Posted February 11, 2017 Share Posted February 11, 2017 4 minutes ago, crossie2709 said: Need some help ive got some mist washer jets fitted on my mk2.5 focus had them one for a year or so and last few days they not been working properly its just dripping out PS ive filled the washer bottle up My rear washer jet wasn't working recently. I took it off and it was just blocked with rubbish and grime. Take it off and give it a clean, I used a sewing needle -worked a treat! Quote Link to comment Share on other sites More sharing options...
Commencal24 Posted February 11, 2017 Share Posted February 11, 2017 Is there a noticeable difference in spray coverage compared to the original ones on a my 2.5? As I'm contemplating getting some. Quote Link to comment Share on other sites More sharing options...
crossie2709 Posted February 11, 2017 Author Share Posted February 11, 2017 When they was working they are much better haha 1 Quote Link to comment Share on other sites More sharing options...
crossie2709 Posted February 11, 2017 Author Share Posted February 11, 2017 My rear washer jet wasn't working recently. I took it off and it was just blocked with rubbish and grime. Take it off and give it a clean, I used a sewing needle -worked a treat! They work they just not as good as the was Quote Link to comment Share on other sites More sharing options...
madman Posted February 12, 2017 Share Posted February 12, 2017 It sounds like filter block in the bottle due to screen wash. On my focus working fine then slowed down to like drip. Had to take wheel lining off to access the bottle. Hope this helps 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted February 18, 2017 Share Posted February 18, 2017 As Madman says, there is a filter between the tank and pump that gets clogged up. Remove the osf wheel, remove the rear part of the arch liner and you'll find the pump on the inward side of the lower part of the tank. Pull off the pump and you'll be able to remove the filter. Best done when the tank is empty or you'll end up with fluid everywhere 3 Quote Link to comment Share on other sites More sharing options...
