Blakebrum Posted April 5, 2019 Share Posted April 5, 2019 Can anyone help? June last year my 2012 echoboost lost power and it struggled to get up hills. I took it to a garage who said the vacume pump had gone and so i had it replaced (cost me over £600). The same thing has happened again, does anyone have a clue what the problem could be. I dont want to pay out another 600 and surely it cant be the vacume pump again. Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted April 5, 2019 Share Posted April 5, 2019 "Echoboost" 😛 Sorry I have literally nothing useful to add here other than see if theres any fault codes. Quote Link to comment Share on other sites More sharing options...
WES180 Posted April 6, 2019 Share Posted April 6, 2019 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F253263801442 Wow, over £600? That's a lot of labour then. Quote Link to comment Share on other sites More sharing options...
H1ghlander1977 Posted April 9, 2019 Share Posted April 9, 2019 Not sure if you got any warnings etc but I got the kinda same issue, engine malfunction service now comes on. Took it to the garage I got it from since I only had it for not even 2 weeks. they say it a vacuum tube/pipe that’s causing the fault. Quote Link to comment Share on other sites More sharing options...
Blakebrum Posted April 20, 2019 Author Share Posted April 20, 2019 On 4/9/2019 at 12:45 PM, H1ghlander1977 said: Not sure if you got any warnings etc but I got the kinda same issue, engine malfunction service now comes on. Took it to the garage I got it from since I only had it for not even 2 weeks. they say it a vacuum tube/pipe that’s causing the fault. Said the same to me they repaired the pipe but still having the same issue and on to of that the coolant pipe is leaking😪 Quote Link to comment Share on other sites More sharing options...
H1ghlander1977 Posted April 21, 2019 Share Posted April 21, 2019 9 hours ago, Blakebrum said: Said the same to me they repaired the pipe but still having the same issue and on to of that the coolant pipe is leaking😪 I also had the vacuum pump removed and cleaned. Tried that? Quote Link to comment Share on other sites More sharing options...
