Retrofit bluetooth
Tjeerd
Hi all,
I just bought a Fiesta and am loving it so far! Only thing I didn't think about was the presence of a bluetooth radio. It came with the standard 6 button radio. Reading up and some of the success and failure stories about swapping out the radio for a different one I am still in a pickle as to what exactly would be required.
Easy list would be:
Radio, facia, display, bluetooth module + loom + mic
All parts can be found but where I get stuck and cannot for the life of me find any relevant information is what the actual correct loom is for the bluetooth module and where it supposed to connect to seeing my current radio has a single 24pin connector. Anyone have some information in regards where the loom from the bluetooth module actually connects to?
If you have mk 7.5, you can put the Sony radio straight forward.
What i did:
First brought the Sony sat nav radio, facia, lcd with bracket and sdcard.
Plug & Play the connectors.
Use Forscan to activate,
-Color, MFD 5
-Navigation system for EU
-Integrated Control Panel - Branded ICP
For the bluetooth, i only buy when i see the full set, loom, micro, bluetooth module, then i know everthing is going to work, its a pain to find the loom.
Its a pain to get all and fit all, but for me worth every penny, and have zero problems.
Thanks for the detailed info and images! Looks like the loom has a dedicated connector that goes into the 26pin slot on the radio? Unfortunately mine is a MK7 or 2008.75.
From some research I found these partnumbers so far:
Radio: AA6T-18C815-XB
Display: AA6T-18B955-GD
Bluetooth: CS7T-14D212-AC
VIN: WF0JXXGAJJCL82651
I also came across a post somewhere that mentioned that if the standard 6 button radio is fitted, it contains a different dashboard harness?
Any idea what the part number for the correct bluetooth harness is?
The loom and module bluetooth
https://www.ebay.co.uk/itm/Fiesta-MK7-2009-2012-Bluetooth-Connectivity-Voice-Control-Module-Cables/254544251028?epid=1723303281&hash=item3b44050894:g:6~4AAOSwoJ5eciFs
bluetooth module where it stays, below the glove box.
The head unit probably need to change to, it need to have 2 connectores, see pic above.
And also you need to find the loom for the microphone, that goes from the A pilar to ceiling light.
You have usb port in central console?
This links are examples just to give you a ideia.
My current radio with the standard 3 line display:
Current radio has USB and line in connected to it. I understood that those will move to the bluetooth module.
As far as I know it doesn't have sync and there's no bluetooth module installed.
Correct, that usb loom needs to be remove from car, the "new" usb connect direct to bluetooth.
You need a head unit too, the Sony may be the way to go.
Lcd i dont know if you can change, maybe someone with that version can help you.
And then Forscan to activate.
Received the new radio and built it in.
IMG_2127.jpg.996460f8f2ce62aac63b7371948549ee.jpg image2.jpeg.c29ab627277751bef14e2bd3a2b560bb.jpeg
Also found the original connector for the bluetooth module. Currently only the aux signal goes through it and still works. Ordered the bluetooth loom for this car which plugs into the same connector: BA6T-14C575-BBC and the bluetooth module: CS7T-14D212-AC
Since this radio has a secondary connector for the bluetooth module, am I correct in assuming it won't be able to make the connection via the builtin 24pin connector? If so, does someone have a pin-out for the 10 pin connector and the 26 pin connector on the back of the radio?
2 hours ago, Tommo17 said:
I’m looking at the same. So you found the connectors for the Bluetooth module ?
Depends on your car, is it with sync or without?
Here are the connector diagrams that I could find on the net for a sync version.
2023292700_radio24pinconnectorsony.thumb.png.cb94707799489d1526e2282ccb0ccb1f.png 1979689416_radio26pinconnectorsony.thumb.png.471fae77e24f29b72dadd1afc67b4053.png 512034279_bluetooth54pinconnectorsync.thumb.png.0746fa2a9efe4d367a8e6d65ba589de4.png
@Tjeerd thanks. I’m guessing it doesn’t have sync judging by etis. I can’t get my hands on it yet till this lockdown is over. It’s my mothers car she sent me this
First succes!
Sony facia
Indicator stalk with voice: 8A6T-13335-CC
bluetooth wiring harness: BA6T-14C575-BBC
BVC: CS7T-14D212-AC
Still to source, DAB antenna and microphone holder for the roof
Updated with forscan and everything works. 2nd connector on the back of the radio stays empty. DAB works, voice, bluetooth, track display etc.
ICE -> High level CD and DAB
Voice control -> Basic speech recognition
Digital radio receiver -> DAB radio system with PTY EU and ROW
bluetooth handsfree -> BT/VC Phone system with USB
  • 1 year later...
Did any one  find the pin out diagram for the 10 pin connector an 54 pin 24 pin connector for bt/vc/USB
Can you send my the courier's on the 10 pin connector please as on photo can't tell them as mine from  ford they de pined them An cap up for some reason
Thanks matt
  • 7 months later...
Good afternoon everyone first post on here I got a 2011 fiesta couple months ago it came with a standard 6 button radio and wanted to retrofit the Sony head unit with usb and bluetooth I purchased and installed the following parts the radio works but the screen is blank, only the radio works none of other buttons work I have coded the following with ForScan
thanks in advance
@Whidds pretty sure you need parts from a pre-facelft car since yours is a 2011, could be wrong
Ye if it the a 2011 you need the sony with silver heater vents and a red or blue matrix screen the sony with black vents from 2013 what I've been told there are slight differences in the wireing
