Alex.S Posted July 31, 2020 Share Posted July 31, 2020 1st summer with the car. Also 1st car I鈥檝e had with heated windscreen..which is great in winter.聽 Got caught in really heavy summer downpour there. Steamed up like crazy. Put blowers on full blast , which didn鈥檛 clear it as fast as I鈥檇 have liked.聽 put the heated windscreen on. Cleared up. What鈥檚 the consensus on that ? Blowers or heated windscreen?聽 Quote Link to comment Share on other sites More sharing options...
sussamb Posted July 31, 2020 Share Posted July 31, 2020 Both 馃檪 2 Quote Link to comment Share on other sites More sharing options...
alexp999 Posted July 31, 2020 Share Posted July 31, 2020 In the summer the aircon should do the job just fine on it's own. I use both in winter though. 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted July 31, 2020 Share Posted July 31, 2020 I'd always use the heated screen for interior mist, much quicker... BUT it really rinses battery voltage, so probably best to stick to blowers on a short journey. If you do use the blowers, you really want the AC on, but that's not ideal on a short journey either...聽 It's a more complicated question than it seems! 聽 1 Quote Link to comment Share on other sites More sharing options...
Wino Posted July 31, 2020 Share Posted July 31, 2020 Man up and get thee windows darn聽馃槀 1 Quote Link to comment Share on other sites More sharing options...
Alex.S Posted July 31, 2020 Author Share Posted July 31, 2020 5 minutes ago, Wino said: Man up and get thee windows darn聽馃槀 That鈥檚 been lost in translation there mate !聽 1 Quote Link to comment Share on other sites More sharing options...
Tizer Posted July 31, 2020 Share Posted July 31, 2020 Aircon if it is steaming up on the inside. Putting the Heated Screen on will just turn it from a liquid to a gas, it doesn't make it go away and unless it is purged from the interior it will condense somewhere else like the side windows. Quote Link to comment Share on other sites More sharing options...
SDHXIII Posted July 31, 2020 Share Posted July 31, 2020 Absolutely spotless clean windows will also help. Microscopic moisture droplets attach to the dirt and dust on the inside of the screen causing the fogging. Getting it spotless is another story altogether. 1 Quote Link to comment Share on other sites More sharing options...
Guy Heaton Posted July 31, 2020 Share Posted July 31, 2020 Do you have recirculation on?聽 That will keep moisture in Quote Link to comment Share on other sites More sharing options...
Alex.S Posted August 1, 2020 Author Share Posted August 1, 2020 17 hours ago, Guy Heaton said: Do you have recirculation on?聽 That will keep moisture in Wasn鈥檛 on. But good logic. Manual says聽 聽 Quote Link to comment Share on other sites More sharing options...
Mark-UK Posted August 1, 2020 Share Posted August 1, 2020 20 hours ago, SDHXIII said: Absolutely spotless clean windows will also help. Microscopic moisture droplets attach to the dirt and dust on the inside of the screen causing the fogging. Getting it spotless is another story altogether. I can vouch for this, my previous car (non ford) was forever misting up on the windows, a real good scrub with a glass cleaner did wonders, but as said it hard to get it spotless. 1 Quote Link to comment Share on other sites More sharing options...
granville_focus Posted August 2, 2020 Share Posted August 2, 2020 Just keep the air conditioning on all the time, best for the a/c also 1 Quote Link to comment Share on other sites More sharing options...
Frowma Posted August 5, 2020 Share Posted August 5, 2020 One thing about Air con on a hot day, the car will put the recirc on to save energy, cheaper to keep the cold air cold than pump in hot air from the outside and then cool it! This could lead to the misting up. Quote Link to comment Share on other sites More sharing options...
alexp999 Posted August 5, 2020 Share Posted August 5, 2020 Just now, Frowma said: One thing about Air con on a hot day, the car will put the recirc on to save energy, cheaper to keep the cold air cold than pump in hot air from the outside and then cool it! This could lead to the misting up. A/C will still de-humidify even with re-circ. Quote Link to comment Share on other sites More sharing options...
