jonparish Posted June 26, 2012 Share Posted June 26, 2012 Hi, I have a problem regarding the front and rear wipers on my MK1 Focus. This was noticed the other day during rain! Front - When I spray the water jets they work fine but there is no wiping movement. On its own the intermittant setting doesn't work at all, yet the faster settings work fine. Rear - When I spray the water jets they work fine but there is no wiping movement. The wiper does not work on its own either. My local garage has tried swapping the Relay and problem does not go away, and also tried swapping the Switch with and the problem still exists. The mechanic believes that both the front and rear motors may need to be replaced, however surely both have not packed up on the same day? Does anybody have an idea of what else this could be? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted June 26, 2012 Share Posted June 26, 2012 When you say they changed the switch do you mean the wiper switch arm or the whole unit (indicator arm included)? You may need a full unit as some contacts may have broken in it. Quote Link to comment Share on other sites More sharing options...
stef123 Posted June 26, 2012 Share Posted June 26, 2012 Are the motors getting power? Check this before you go replacing them Quote Link to comment Share on other sites More sharing options...
Dan62 Posted June 26, 2012 Share Posted June 26, 2012 It sounds like the GEM is the problem here, it controls the intermittent functions of the wipers and turning them on when the washers are used. The rear wiper motor (I think) is always intermittent except when the washers are used so that should explain why the rear motor doesn't function at all. (it is always controlled by the GEM). Well worth checking all the fuses first, the control circuit may rely on a different fuse to the wipers. Quote Link to comment Share on other sites More sharing options...
jonparish Posted June 26, 2012 Author Share Posted June 26, 2012 Thanks for your replies. The mechanic tried a different wiper stalk, not the unit including the indicator stalk. Regarding the wiper getting power, if the water is spraying does this mean the power is ok? Just from googling GEM I believe these are in Focus's after 2001, mine is 2000 so has a CTM? I think the fuses are all ok, however having read this thread..http://www.rac.co.uk/forum/showthread.php?5547-Ford-Focus-electrical-misfire-problem.. I see there is correlation with the coil..interestingly I had a problem with power last week, and the diagnostic was a multiple misfire fault, therefore the coil was replaced. Does this help anyone further? Thanks again guys. Quote Link to comment Share on other sites More sharing options...
stef123 Posted June 26, 2012 Share Posted June 26, 2012 No you need to check for power at the wipers. The washers are fed from a different circuit Quote Link to comment Share on other sites More sharing options...
jonparish Posted June 26, 2012 Author Share Posted June 26, 2012 Thanks for helping Stef, how do I go about that? Quote Link to comment Share on other sites More sharing options...
stef123 Posted June 27, 2012 Share Posted June 27, 2012 Start by putting a voltmeter on the connector for the motor and have someone operate it. If your are getting 12v then your motor is dead more than likely. If not getting 12v then you will need to have a better look at the wiring etc Quote Link to comment Share on other sites More sharing options...
jonparish Posted July 3, 2012 Author Share Posted July 3, 2012 To all, I had a quick play with the fuses and the relays yesteday evening before I got round to checking the power of the motor, as a number of other issues such as the rear screen heater not working and the lights on/door opening sound not operating made me think it was more of a CTM/GEM issue. By a stroke of luck, everything seems to be working now so i'll leave it at that, but its a good time to get rid of the car now I think. Thanks to you all for your help and advice. Quote Link to comment Share on other sites More sharing options...
