busajohn Posted September 27, 2012 Share Posted September 27, 2012 Hi everyone i have a 57 plate 2 ltr tdci ghia mondeo and for the last 3 days my abs..esp light has stayed on my dash..cleaned both abs sensors on front but the lights are still on Anyone help ,e plz TIa ,,,John Quote Link to comment Share on other sites More sharing options...
busajohn Posted September 28, 2012 Author Share Posted September 28, 2012 any help before i have to pay £120 for it to go on a machine ...thanks Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 28, 2012 Share Posted September 28, 2012 You'll probably find you need to clear the fault codes from the system. Anyone with an OBDII reader can do it. Quote Link to comment Share on other sites More sharing options...
ppeter7 Posted September 28, 2012 Share Posted September 28, 2012 how about rear ones have you checked wires arnt broke Quote Link to comment Share on other sites More sharing options...
busajohn Posted September 28, 2012 Author Share Posted September 28, 2012 ppeter7...yes mate we done the back ones aswell Quote Link to comment Share on other sites More sharing options...
busajohn Posted September 28, 2012 Author Share Posted September 28, 2012 You'll probably find you need to clear the fault codes from the system. Anyone with an OBDII reader can do it. thanls for your reply//a mate put a fault code reader on...John it...was a handheld one but no code come up..he said it didnt read abs faults Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 28, 2012 Share Posted September 28, 2012 Any garage with a professional reader will be able to look deeper for codes. A lot of the time even when a fault is fixed the code stays resident on the system until read and cleared so warning lights and fault warnings will still show. Quote Link to comment Share on other sites More sharing options...
busajohn Posted September 28, 2012 Author Share Posted September 28, 2012 Any garage with a professional reader will be able to look deeper for codes. A lot of the time even when a fault is fixed the code stays resident on the system until read and cleared so warning lights and fault warnings will still show. ok thanks Quote Link to comment Share on other sites More sharing options...
busajohn Posted September 29, 2012 Author Share Posted September 29, 2012 i dont know if this makes any difference to my problem..but last night i noticed my antilock brakes are not working and the button for the traction control(esp)on dash wont go on or off...thanks Quote Link to comment Share on other sites More sharing options...
stef123 Posted September 29, 2012 Share Posted September 29, 2012 Your abs will not work as there is a fault. Have you checked the connections at the sensors and under the car? Quote Link to comment Share on other sites More sharing options...
busajohn Posted September 29, 2012 Author Share Posted September 29, 2012 Your abs will not work as there is a fault. Have you checked the connections at the sensors and under the car? thanks for your reply..i dont know anything about car bits...but a mate at the bottom of the road has took all the sensor plugs of and cleaned them front and raer ..thats all i know...John Quote Link to comment Share on other sites More sharing options...
busajohn Posted October 1, 2012 Author Share Posted October 1, 2012 Just want to say thanks to you all for your help..My drivers side front sensor has gone so ordered one from ford £29 bit of confusion if this will sort out the esp aswell as abs aswell ...John Quote Link to comment Share on other sites More sharing options...
stef123 Posted October 1, 2012 Share Posted October 1, 2012 Just want to say thanks to you all for your help..My drivers side front sensor has gone so ordered one from ford £29 bit of confusion if this will sort out the esp aswell as abs aswell ...John The ESP takes it reading from the abs system so the chances are it will sort that out too Quote Link to comment Share on other sites More sharing options...
busajohn Posted October 1, 2012 Author Share Posted October 1, 2012 The ESP takes it reading from the abs system so the chances are it will sort that out too ok thanks for that Quote Link to comment Share on other sites More sharing options...
busajohn Posted October 2, 2012 Author Share Posted October 2, 2012 Hi again ..can someone help ..i went to my local ford dealer and told them i wanted a abs/esp sensor front drivers side he told me £29 so i ordered it /went to pick up this morning and the (tw*t ) ordred me a wiring loom for the sensor ..then he said i will order the sensor now its a whoping £91 anyone know a part number... thanks Quote Link to comment Share on other sites More sharing options...
busajohn Posted October 5, 2012 Author Share Posted October 5, 2012 hello again..right i got my sensor and fitted it but the light on my dash are still on ..will i have to have them cleared with a fault reader or should they have gone off when new sensor was fitted,,,thanks ,jOHN Quote Link to comment Share on other sites More sharing options...
busajohn Posted October 6, 2012 Author Share Posted October 6, 2012 anyone recomend a fault reader that does abs/esp plz...John Quote Link to comment Share on other sites More sharing options...
busajohn Posted October 12, 2012 Author Share Posted October 12, 2012 update for you all.. fitted the new sensor ..when ignition is switched on the abs/esp go out after say 5 seconds but as soon as you drive off they come back on...look like a ford jobby ,,,John Quote Link to comment Share on other sites More sharing options...
stef123 Posted October 12, 2012 Share Posted October 12, 2012 Have you checked the and ring on the shaft? Quote Link to comment Share on other sites More sharing options...
busajohn Posted October 12, 2012 Author Share Posted October 12, 2012 Have you checked the and ring on the shaft? i dont know anything about cars..i have to relay messages to a mate ..what ring n shaft thanks Quote Link to comment Share on other sites More sharing options...
stef123 Posted October 13, 2012 Share Posted October 13, 2012 i dont know anything about cars..i have to relay messages to a mate ..what ring n shaft thanks im not sure what your car has but the abs sensor will pick its signal from a ring which is fitted to the end of the driveshaft or sometimes from the wheel bearing itself. if whatever one of these your car has is damaged the ecu will throw an error up for that wheel. Quote Link to comment Share on other sites More sharing options...
busajohn Posted October 14, 2012 Author Share Posted October 14, 2012 im not sure what your car has but the abs sensor will pick its signal from a ring which is fitted to the end of the driveshaft or sometimes from the wheel bearing itself. if whatever one of these your car has is damaged the ecu will throw an error up for that wheel. m4 2l tdci ghia Quote Link to comment Share on other sites More sharing options...
