gjevans1992 Posted August 1, 2014 Share Posted August 1, 2014 Hi all, Just a quick question, I want to change my sidelights to match my bulbs that I have used to replace the factory dippee lights and the owners manual states that the sidelights output 5watts of power each The ones I have seen are 12volts each and I was wondering would these be okay to use to replace the factory ones as most bulbs are measured in volts not watts, as I don't want to melt the wiring loom All help is appreciated Thank you Sent from my SM-N9005 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Nathan54771 Posted August 1, 2014 Share Posted August 1, 2014 All cars work off 12 volts so the bulbs will all be 12v even standard. What have you replaced your dipped beam with ? Then I can recommend some sidelights according 1 Quote Link to comment Share on other sites More sharing options...
gjevans1992 Posted August 1, 2014 Author Share Posted August 1, 2014 I replaced my dipped headlights with osram night breakers I'm trying to get that really bright white light effect :) Thank you Sent from my SM-N9005 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Nathan54771 Posted August 1, 2014 Share Posted August 1, 2014 Try these, you won't be dissapointed :) really good sidelight bulbs. http://m.ebay.co.uk/itm/321470682857?nav=SEARCH 1 Quote Link to comment Share on other sites More sharing options...
gjevans1992 Posted August 1, 2014 Author Share Posted August 1, 2014 Does my car use canbas as I can't see it anywhere in the manual aha Thanks Sent from my SM-N9005 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Mike77 Posted August 1, 2014 Share Posted August 1, 2014 Agree with Nathan,,, got them bulbs in mine, and they are the brightest, most white sidelight bulb you'll ever come across. 1 Quote Link to comment Share on other sites More sharing options...
Mike77 Posted August 1, 2014 Share Posted August 1, 2014 And I'm pretty sure your car doesn't use canbus. Quote Link to comment Share on other sites More sharing options...
Nathan54771 Posted August 1, 2014 Share Posted August 1, 2014 Doesn't matter if it's canbus the bulb or not, your car isn't canbus so it's irrelevant. Just get the ones linked and as above there the best you can get that I know of :) hope that helps 1 Quote Link to comment Share on other sites More sharing options...
gjevans1992 Posted August 1, 2014 Author Share Posted August 1, 2014 Fantastic thank you for all your help Mike :) Sent from my SM-N9005 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
M4RC Posted August 3, 2014 Share Posted August 3, 2014 LEDs generally consume a lot less power so you'll never have to worry about that... 1 Quote Link to comment Share on other sites More sharing options...
