Bannko Posted March 6, 2017 Share Posted March 6, 2017 Yep, on the russian site chipford.ru are now located other language packs for v3.10. They are not included in separate usb-installation packages but only as a standalone .zip files. I assume that we can replace the language pack inside the v.3.10 installation, edit the autoinstall.lst file and then simply install. But yeah we need some volunteers wiling to try it on their device :) Quote Link to comment Share on other sites More sharing options...
vincentka Posted March 6, 2017 Share Posted March 6, 2017 21 minutes ago, Bannko said: But yeah we need some volunteers wiling to try it on their device :) Yes :) but probably all will be OK Quote Link to comment Share on other sites More sharing options...
Ormet Posted March 6, 2017 Share Posted March 6, 2017 1 hour ago, vincentka said: Yes :) but probably all will be OK Did not work with the main install file on the .ru site, Install fail at once. But then I got a link to another 3.10 version. Just put my language pack in it and edit the autointall.lst All went fine until the end of the last file in my language pack. Got an install failure but all seems fine. It complained abouth not enough space. Maybe it is necessary to remove the main language pack when adding another pack? Everything works ok. Can´t see anything wrong. BTW, does sync control the audio levels? I am not sure if it is a placebo effect but it seems that the audio level from the rear Speakers is a little higher than before. Quote Link to comment Share on other sites More sharing options...
vincentka Posted March 6, 2017 Share Posted March 6, 2017 5 minutes ago, Ormet said: Did not work with the main install file on the .ru site, Install fail at once. But then I got a link to another 3.10 version. Just put my language pack in it and edit the autointall.lst All went fine until the end of the last file in my language pack. Got an install failure but all seems fine. It complained abouth not enough space. Maybe it is necessary to remove the main language pack when adding another pack? Everything works ok. Can´t see anything wrong. BTW, does sync control the audio levels? I am not sure if it is a placebo effect but it seems that the audio level from the rear speakers is a little higher than before. Put here Yours autoinistall here . Lets look Quote Link to comment Share on other sites More sharing options...
Ormet Posted March 6, 2017 Share Posted March 6, 2017 1 minute ago, vincentka said: Put here Yours autoinistall here . Lets look ;+++++++++++++++++++++++++++++++++++++++++++++++ ; Microsoft Windows Automotive ; USB Installation Directive File ; 3.10 (15180) Update from: ; 10308,10337,11038,11063,11081,11134 ; 12023,12047,12058,12156,12285,13164, ; 13171, 13213, 13249, 13269, 13283, 13284, 13309, 13312 ; 14073, 14122, 15042, 15050, 15085, 15091, 15109, 15128 ; Other versions not supported ; autoinstall.lst (EU-Lang pack2 EN-GB_PL-PL_DE-DE_RU-RU) ; ; ; ; FORD EXPERTS ;+++++++++++++++++++++++++++++++++++++++++++++++ ;;; ;;; The following tags are software versions supported by this update ;;; [SYNCGen2_4.23.11038] [SYNCGen2_4.23.11063] [SYNCGen2_4.23.11081] [SYNCGen2_4.23.11134] [SYNCGen2_4.26.12023] [SYNCGen2_4.28.12156] [SYNCGen2_4.29.12285] Item1 = BT4T-14D546-EE Open1 = SyncMyRide\BT4T-14D546-EE.cab Item2 = EA5T-14D546-AKB Open2 = SyncMyRide\EA5T-14D546-AKB.cab Item3 = EA5T-14D546-HB Open3 = SyncMyRide\EA5T-14D546-HB.cab Item4 = EA5T-14D546-ACB Open4 = SyncMyRide\EA5T-14D546-ACB.zip Item5 = BT4T-14D546-FB Open5 = SyncMyRide\BT4T-14D546-FB.cab Item6 = EA5T-14D546-AHB Open6 = SyncMyRide\EA5T-14D546-AHB.cab Item7 = EA5T-14D546-ADB Open7 = SyncMyRide\EA5T-14D546-ADB.cab Item8 = EA5T-14D546-AEB Open8 = SyncMyRide\EA5T-14D546-AEB.cab Options = AutoInstall ;;; ;;; This tag runs only on Zodiac pre-release tags ;;; [SYNCGen2_4.30.13171] [SYNCGen2_4.32.14073] [SYNCGen2_4.32.14122] [SYNCGen2_3.08.15042] [SYNCGen2_3.08.15050] [SYNCGen2_3.08.15085] [SYNCGen2_3.08.15091] [SYNCGen2_3.08.15109] [SYNCGen2_3.08.15128] Item1 = BT4T-14D546-EE Open1 = SyncMyRide\BT4T-14D546-EE.cab Item2 = EA5T-14D546-AKB Open2 = SyncMyRide\EA5T-14D546-AKB.cab Item3 = EA5T-14D546-HB Open3 = SyncMyRide\EA5T-14D546-HB.cab Item4 = BT4T-14D546-FB Open4 = SyncMyRide\BT4T-14D546-FB.cab Item5 = EA5T-14D546-AHB Open5 = SyncMyRide\EA5T-14D546-AHB.cab Item6 = EA5T-14D546-ADB Open6 = SyncMyRide\EA5T-14D546-ADB.cab Item7 = EA5T-14D546-AEB Open7 = SyncMyRide\EA5T-14D546-AEB.cab Options = AutoInstall ;;; ;;; The following are the 3.10.16180 image files ;;; [SYNCGen2_3.10.16180] Item1 = EA5T-14D546-AFB Open1 = SyncMyRide\EA5T-14D546-AFB.cab Item2 = DM5T-14D621-AB Open2 = SyncMyRide\DM5T-14D621-AB.CAB Item3 = EA5T-14D546-DF Open3 = SyncMyRide\EA5T-14D546-DF.ZIP Item4 = EA5T-14D546-FE Open4 = SyncMyRide\EA5T-14D546-FE.ZIP Item5 = EA5T-14F496-AE Open5 = SyncMyRide\EA5T-14F496-AE.ZIP Item6 = EA5T-14F497-CF Open6 = SyncMyRide\EA5T-14F497-CF.ZIP Item7 = EA5T-14F657-AG Open7 = SyncMyRide\EA5T-14F657-AG.ZIP Item8 = EA5T-14D546-AGB Open8 = SyncMyRide\EA5T-14D546-AGB.cab Item9 = BT4T-14D546-EE Open9 = SyncMyRide\BT4T-14D546-EE.cab Item10 = EA5T-14D546-LB Open10 = SyncMyRide\EA5T-14D546-LB.cab Item11 = EA5T-14F497-EF_64706 Open11 = SyncMyRide\EA5T-14F497-EF_64706.zip Options = AutoInstall ;;; ;;; This tag runs only on Zodiac pre-release tags ;;; [SYNCGen2_4.30.13171] [SYNCGen2_4.32.14073] [SYNCGen2_4.32.14122] [SYNCGen2_3.08.15042] [SYNCGen2_3.08.15050] [SYNCGen2_3.08.15085] [SYNCGen2_3.08.15091] [SYNCGen2_3.08.15109] [SYNCGen2_3.08.15128] Item1 = BT4T-14D546-EE Open1 = SyncMyRide\BT4T-14D546-EE.cab Item2 = EA5T-14D546-AKB Open2 = SyncMyRide\EA5T-14D546-AKB.cab Item3 = EA5T-14D546-HB Open3 = SyncMyRide\EA5T-14D546-HB.cab Item4 = BT4T-14D546-FB Open4 = SyncMyRide\BT4T-14D546-FB.cab Item5 = EA5T-14D546-AHB Open5 = SyncMyRide\EA5T-14D546-AHB.cab Item6 = EA5T-14D546-ADB Open6 = SyncMyRide\EA5T-14D546-ADB.cab Item7 = EA5T-14D546-AEB Open7 = SyncMyRide\EA5T-14D546-AEB.cab Options = AutoInstall ;;; ;;; This tag runs only if none of the other tags match ;;; [SYNCGen2_All] Item1 = BT4T-14D546-EE Open1 = SyncMyRide\BT4T-14D546-EE.cab Item2 = EA5T-14D546-NB Open2 = SyncMyRide\EA5T-14D546-NB.cab Options = AutoInstall Quote Link to comment Share on other sites More sharing options...
vincentka Posted March 6, 2017 Share Posted March 6, 2017 2 minutes ago, Ormet said: Item6 = EA5T-14F497-CF Open6 = SyncMyRide\EA5T-14F497-CF.ZIP You change this ? Quote Link to comment Share on other sites More sharing options...
vincentka Posted March 6, 2017 Share Posted March 6, 2017 4 minutes ago, Ormet said: Item11 = EA5T-14F497-EF_64706 Open11 = SyncMyRide\EA5T-14F497-EF_64706.zip aa You add next language package ... but why ? Quote Link to comment Share on other sites More sharing options...
Ormet Posted March 6, 2017 Share Posted March 6, 2017 2 minutes ago, vincentka said: You change this ? Item11 = EA5T-14F497-EF_64706Open11 = SyncMyRide\EA5T-14F497-EF_64706.zip in the The following are the 3.10.16180 image files part (my language pack) Quote Link to comment Share on other sites More sharing options...
Ormet Posted March 6, 2017 Share Posted March 6, 2017 2 minutes ago, vincentka said: aa You add next language package ... but why ? Not sure what happend if I removed something so I just add an item11 Quote Link to comment Share on other sites More sharing options...
vincentka Posted March 6, 2017 Share Posted March 6, 2017 9 minutes ago, Ormet said: Not sure what happend if I removed something so I just add an item11 Item11 = EA5T-14F497-EF_64706Open11 = SyncMyRide\EA5T-14F497-EF_64706.zip EA5T-14F497-CF is language pack ........ only replace for Your country package :) Quote Link to comment Share on other sites More sharing options...
Ormet Posted March 6, 2017 Share Posted March 6, 2017 2 minutes ago, vincentka said: Item11 = EA5T-14F497-EF_64706Open11 = SyncMyRide\EA5T-14F497-EF_64706.zip EA5T-14F497-CF is language pack ........ only replace for Your country package :) Ah, ok. But can I flash it again? Quote Link to comment Share on other sites More sharing options...
vincentka Posted March 6, 2017 Share Posted March 6, 2017 2 minutes ago, Ormet said: But can I flash it again? Not needed now :D Quote Link to comment Share on other sites More sharing options...
Pepsi1 Posted March 7, 2017 Share Posted March 7, 2017 Hello, could i get a download link for the 3.10 version? thank you! 1 Quote Link to comment Share on other sites More sharing options...
Daniel1 Posted March 7, 2017 Share Posted March 7, 2017 Could I get a link as well please? I have a 2015 focus titanium x, with satnav - not sure if that makes any difference. Thanks! 1 Quote Link to comment Share on other sites More sharing options...
Kyutu Posted March 7, 2017 Share Posted March 7, 2017 Many thanks for the chance at installing this update, I installed it on to my Mondeo 2015 with nav and all seems to work fine. As others have said, it took roughly 30mins with various reboots and all was up and running. Have not properly tested out sat nav yet but will come back and chime in once I do. Thanks again! 1 Quote Link to comment Share on other sites More sharing options...
NortonSS Posted March 7, 2017 Share Posted March 7, 2017 Could you send me the link to update my SYNC 2 system for my 2016 Ford Focus Titanium X with navigation. Many Thanks 1 Quote Link to comment Share on other sites More sharing options...
vincentka Posted March 7, 2017 Share Posted March 7, 2017 Sync2 USB update package to 3.10 (16180) version for North America. EU_LANGUAGE PACKAGE Please look inside autoinstall :) 1 Quote Link to comment Share on other sites More sharing options...
Danfromwales04 Posted March 7, 2017 Share Posted March 7, 2017 Can you send me the link to update to v3.10 please? Tia Quote Link to comment Share on other sites More sharing options...
vincentka Posted March 7, 2017 Share Posted March 7, 2017 27 minutes ago, Danfromwales04 said: Can you send me the link to update to v3.10 please? Tia look UP Quote Link to comment Share on other sites More sharing options...
vincentka Posted March 7, 2017 Share Posted March 7, 2017 On 6.03.2017 at 7:12 PM, vincentka said: Here You have language packages Quote Link to comment Share on other sites More sharing options...
JoaDG Posted March 7, 2017 Share Posted March 7, 2017 4 hours ago, vincentka said: Sync2 USB update package to 3.10 (16180) version for North America. EU_LANGUAGE PACKAGE Please look inside autoinstall :) First of all thank you very much for your work I'm from South America and I have a Fiesta Titanium with Sync2 (15128) made in Mexico. I'm almost sure that this factory is the one that makes the Fiesta for the North American market as well. So do you think I will be fine using the update you provided + the South American language pack listed on chipford.ru? If so, how should I install that language pack? Should I change Item7 = EA5T-14F497-AE Open7 = SyncMyRide\EA5T-14F497-AE.ZIP To match the language pack downloaded from chipford.ru? Regards, Quote Link to comment Share on other sites More sharing options...
NortonSS Posted March 8, 2017 Share Posted March 8, 2017 Bannko thanks for sending me the latest update for Sync2. I downloaded and extracted the update onto a pen drive formatted to Fat32. The pen drive now contains a file called Gen2v310build1681updatepackageEULlangpack2, when this file is opened its got two other called:- a) SyncMyRide b) autoinstall.lst Is this correct ? Is it just a case now of inserting the pen drive and do the update. Thanks Quote Link to comment Share on other sites More sharing options...
Bannko Posted March 8, 2017 Share Posted March 8, 2017 2 minutes ago, NortonSS said: Bannko thanks for sending me the latest update for Sync2. I downloaded and extracted the update onto a pen drive formatted to Fat32. The pen drive now contains a file called Gen2v310build1681updatepackageEULlangpack2, when this file is opened its got two other called:- a) SyncMyRide b) autoinstall.lst Is this correct ? Is it just a case now of inserting the pen drive and do the update. Thanks Hi Norton, exactly...just the same procedure as with the previous update. Please check the firs post of this thread. :) Quote Link to comment Share on other sites More sharing options...
Bannko Posted March 8, 2017 Share Posted March 8, 2017 14 hours ago, JoaDG said: First of all thank you very much for your work I'm from South America and I have a Fiesta Titanium with Sync2 (15128) made in Mexico. I'm almost sure that this factory is the one that makes the Fiesta for the North American market as well. So do you think I will be fine using the update you provided + the South American language pack listed on chipford.ru? If so, how should I install that language pack? Should I change Item7 = EA5T-14F497-AE Open7 = SyncMyRide\EA5T-14F497-AE.ZIP To match the language pack downloaded from chipford.ru? Regards, Yest, thanks to the links that Vincentka has provided to us. You should only download the language pack, copy it into the v3.10 update "SyncMyRide" folder and change the language pack in autoinstall.lst accordingly. Quote Link to comment Share on other sites More sharing options...
vincentka Posted March 8, 2017 Share Posted March 8, 2017 3 hours ago, Bannko said: Yest, thanks to the links that Vincentka has provided to us. You should only download the language pack, copy it into the v3.10 update "SyncMyRide" folder and change the language pack in autoinstall.lst accordingly. :) Quote Link to comment Share on other sites More sharing options...
