Sneaky1 Posted May 19, 2022 Share Posted May 19, 2022 Hi, can someone tell me where I can buy online the O-rings and 22mm heater hose please. I contacted my local Ford store and was told I need to replace the while heater matrix for two simple O-rings. Are the Mk2 O-rings the same size as the Mk3 O-rings? Correct me, the 22mm is the inside diameter? Quote Link to comment Share on other sites More sharing options...
fladavid Posted June 4, 2022 Share Posted June 4, 2022 On 5/19/2022 at 2:36 AM, Sneaky1 said: Hi, can someone tell me where I can buy online the O-rings and 22mm heater hose please. I contacted my local Ford store and was told I need to replace the while heater matrix for two simple O-rings. Are the Mk2 O-rings the same size as the Mk3 O-rings? Correct me, the 22mm is the inside diameter? I didn't feel confident enough to replace mine so I took mine to a Ford Authorised garage, Jacksons in Teddington, and they replaced the O rings only, so they are available. That was over a year ago and fingers crossed its still holding firm. Quote Link to comment Share on other sites More sharing options...
Sneaky1 Posted July 29, 2022 Share Posted July 29, 2022 On 12/31/2017 at 4:35 AM, Flatfour said: The part numbers are as follows: Clips 1454337 O rings 1342708 Parts cost circa £14 Does anyone know if there is a place in Australia I can order these from, Ford are no help at all. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted July 29, 2022 Share Posted July 29, 2022 2 hours ago, Sneaky1 said: Does anyone know if there is a place in Australia I can order these from, Ford are no help at all. Have you tried eBay? Quote Link to comment Share on other sites More sharing options...
harbottle Posted July 29, 2022 Share Posted July 29, 2022 Just done this same repair today after reading all the advice here. I feared the worst with a head gasket failure but it was indeed the o-rings. I replaced the 2 o-rings and the 2 clamps. £20.90 for the 4 items. I took around 1.5 hours. Half hour of that was looking for my glasses after I launched them in temper. To be fair, the old clips came off ok and were reusable. Hopefully it has cured the problem, if not it will be the hose and jubilee clip option. Thank you for the advice here all, it helped me a lot. The broken one was from the top pipe, the bottom one lookes like new. 1 Quote Link to comment Share on other sites More sharing options...
Madusha Posted October 15, 2022 Share Posted October 15, 2022 On 7/29/2022 at 7:01 PM, harbottle said: Just done this same repair today after reading all the advice here. I feared the worst with a head gasket failure but it was indeed the o-rings. I replaced the 2 o-rings and the 2 clamps. £20.90 for the 4 items. I took around 1.5 hours. Half hour of that was looking for my glasses after I launched them in temper. To be fair, the old clips came off ok and were reusable. Hopefully it has cured the problem, if not it will be the hose and jubilee clip option. Thank you for the advice here all, it helped me a lot. The broken one was from the top pipe, the bottom one lookes like new. Same problem.Can you explain me how to do this. Quote Link to comment Share on other sites More sharing options...
Ros Wall-Clarke Posted December 24, 2022 Share Posted December 24, 2022 I have an 05 focus and just had terrifyingly experience with sudden leak of boiling water onto my right foot from the left of the footwell. I was driving on a busy road at the time. A passer by told me it was most likely the heater matrix. I had thought the car would burst into flames. 1 Quote Link to comment Share on other sites More sharing options...
Sooty1977 Posted June 1, 2023 Share Posted June 1, 2023 I have the same issue in my 2013 focus. The leak isn't massive but it is wetting the footwell (and draining the coolant). However, has anyone tried putting duct or electricians tape around the join instead? Just wondered if that would work? 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted June 1, 2023 Share Posted June 1, 2023 12 minutes ago, Sooty1977 said: I have the same issue in my 2013 focus. The leak isn't massive but it is wetting the footwell (and draining the coolant). However, has anyone tried putting duct or electricians tape around the join instead? Just wondered if that would work? Electrical tape won't work. Not waterproof or heatproof. Self amalgamating tape may work, but I don't think there's enough space to wrap it properly. If no one has found a bodge by now, chances are there probably isn't one. Quote Link to comment Share on other sites More sharing options...
unofix Posted June 1, 2023 Share Posted June 1, 2023 2 hours ago, TomsFocus said: If no one has found a bodge by now, chances are there probably isn't one. Isetta will know a bodge for it 🤣 1 Quote Link to comment Share on other sites More sharing options...
Sooty1977 Posted June 1, 2023 Share Posted June 1, 2023 Thanks, I might give self amalgamating tape a chance. It'll be quicker and worth a fiver to give it a go! 1 Quote Link to comment Share on other sites More sharing options...
Sooty1977 Posted June 2, 2023 Share Posted June 2, 2023 I tried with the tape. You are right there isn't much leverage to wrap it around. Doubt it'll do much good. For now, it's looking like a garage job as I can't see myself repairing it without aid. Thanks anyway, great forum! 1 Quote Link to comment Share on other sites More sharing options...
