squidsdad Posted June 4, 2019 Share Posted June 4, 2019 Any ideas for this SLM32 Cheers. Quote Link to comment Share on other sites More sharing options...
fahim Posted June 20, 2019 Share Posted June 20, 2019 hi i see on my ford Test DTC #01 C200-00 / #02 C199-00 /#03 C100-00 /#04 F006-16 plz if anyone can explain me if something is wrong in my car Quote Link to comment Share on other sites More sharing options...
michael 90 Posted July 6, 2019 Share Posted July 6, 2019 got a ford focus st3 2012 dtc e10100 can anyone help Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 6, 2019 Share Posted July 6, 2019 How did you obtain that code?If via dash check then it's meaningless plus too many numbers for a true dtc.You need a proper code reader to get accurate readings.Sent from my SM-G965F using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
mu_fathi Posted September 2, 2019 Share Posted September 2, 2019 i do not have "none" in dtc code menu i have a number (010181)... what is that mean!!?? Quote Link to comment Share on other sites More sharing options...
JimHD59CMX Posted October 4, 2019 Share Posted October 4, 2019 Ford Focus 2009 2.0L automatic Engine Malfunction DTC 02E11 what does this code mean. Engines runs but obviously I don't want to drive it until I find out what this code means. Any help as local ford garage unhelpful so far. Quote Link to comment Share on other sites More sharing options...
Tamarah_kh Posted November 30, 2019 Share Posted November 30, 2019 Hallo, My dad asked my to find the fault codes for his FORD FOCUS 1.4 benzine, year 1999, combi MK1, DNW. Am I in the right site? Thank you so much! Quote Link to comment Share on other sites More sharing options...
lisa1979 Posted January 11, 2020 Share Posted January 11, 2020 hi there recently bought a 2009 ford focus everything been great then all of a sudden the engine management light keeps coming on now i been googling and found the test trick done that and im getting codes DTC E510,, DTC D147,, and DTC D900 anyone know what these mean please as i cannot find anything thanks lisa Quote Link to comment Share on other sites More sharing options...
pcaouolte Posted January 12, 2020 Share Posted January 12, 2020 E510 = U2510 = (CAN) Lack of acknowledgement from engine management D147 = U1147 = SCP (J1850) Invalid or missing data for vehicle security D900 = U1900 = CAN Communication bus fault Might be a loose connection somewhere, possibly in the instrument cluster (often go faulty and need re-soldering) or at the fuse box behind the glove compartment (the big plugs that connect into the fuse box sometimes get knocked loose). Quote Link to comment Share on other sites More sharing options...
Jordandavis Posted May 8, 2020 Share Posted May 8, 2020 Hello just brought a Ford Focus 1.8 09 plate drove for 5 mins now won’t start we thought it was a flat battery brought a new one no luck won’t start says engine malfunction now too code are d900 e510 and d147 Quote Link to comment Share on other sites More sharing options...
Botus Posted May 9, 2020 Share Posted May 9, 2020 the post above yours... is the same codes u list... how can u drive for 5 mins then won't start.... do u mean it cut out? did u steal it? from the list above sounds to me like the ignition key / immobiliser / fuel pressure, it shouldn't start if the immobiliser isn't not happy, if it ran then dies soon after then it could be a signal to keep the fuel pressure up, dropped out..... which again could be the issue listed around an instrument cluster fault ??? Quote Link to comment Share on other sites More sharing options...
Hieronymous Posted May 15, 2020 Share Posted May 15, 2020 Greetings. I have 3 fault codes on my 2008 1.8 petrol focus which I think are just stored after I had a battery problem. 9318 is mentioned previously but 9106 and A103 are what? I'd be interested to know especially if I'm wrong about them just being stored. Talking of which would the capacitor discharge system work in erasing them? Oh! I used the self diagnostic on the dash to get these codes. Quote Link to comment Share on other sites More sharing options...
Hieronymous Posted May 16, 2020 Share Posted May 16, 2020 Well, I found out that A103 means antenna not plugged in so I just have to discover what 9106 means now. Quote Link to comment Share on other sites More sharing options...
brumie Posted October 9, 2020 Share Posted October 9, 2020 i have a 2015 ford galaxy 2.0l auto today it went into limp mode on the dash it said transmission fault and Tr10 then Tr11 and Tr12 any ideas Quote Link to comment Share on other sites More sharing options...
Benh51 Posted December 8, 2020 Share Posted December 8, 2020 Hi all, I got 1301 any way I can fix this myself or is it serious. Quote Link to comment Share on other sites More sharing options...
Goliat Posted May 25, 2021 Share Posted May 25, 2021 Ford Focus 2L TDCI, fault codes P0299 and P2263 After it was serviced it wouldn't start until we pulled it with another vehicle.. What could be wrong with it? Thanks Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 25, 2021 Share Posted May 25, 2021 1 hour ago, Goliat said: Ford Focus 2L TDCI, fault codes P0299 and P2263 After it was serviced it wouldn't start until we pulled it with another vehicle.. What could be wrong with it? Thanks If it had a fuel filter change, it wasn't bled through properly if it needed a tow start. Those codes are boost related so unlikely be linked. I'd suspect a loose or split boost hose somewhere. Quote Link to comment Share on other sites More sharing options...
pcarruthers4 Posted July 10, 2021 Share Posted July 10, 2021 I have an engine light fault, I've hooked it up to to diagnostic and its giving a error code 9492 unknown. Anyone have any idea what this is? Quote Link to comment Share on other sites More sharing options...
Tizer Posted July 10, 2021 Share Posted July 10, 2021 36 minutes ago, pcarruthers4 said: I have an engine light fault, I've hooked it up to to diagnostic and its giving a error code 9492 unknown. Anyone have any idea what this is? I think you need a better code reader. Quote Link to comment Share on other sites More sharing options...
unofix Posted July 10, 2021 Share Posted July 10, 2021 2 hours ago, pcarruthers4 said: error code 9492 Does not compute !! Use ForScan and get a DTC that gives more information. Quote Link to comment Share on other sites More sharing options...
Jess87 Posted July 14, 2021 Share Posted July 14, 2021 14 Ford Focus Codes received from dealership U01012 U101113 Can't find these codes on any forum. We know it's a TCM issue Quote Link to comment Share on other sites More sharing options...
unofix Posted July 14, 2021 Share Posted July 14, 2021 5 hours ago, Jess87 said: U01012 U101113 Those might mean something to a Ford main dealer but not to the rest of the world. Why don't you use ForScan its free - https://forscan.org/download.html and get a ELM327 lead from eBay, then you might get some information and codes that mean something to those on this forum 1 Quote Link to comment Share on other sites More sharing options...
Jez b Posted July 31, 2021 Share Posted July 31, 2021 Hi I have a ford focus mk3.5 st 3 diesel got engine management light on and a dtc code c073_88 does anyone know what the fault is please Quote Link to comment Share on other sites More sharing options...
unofix Posted July 31, 2021 Share Posted July 31, 2021 "C073_88 - it U0073 Definition: Bus data transmission control module off" not that is probably much help. Firstly disconnect your battery and leave it off for twenty minutes before reconnecting it. This will cause all modules to go through the wake-up and may well clear the communication fault. If that fails then you need to get a laptop, an ELM327 lead and ForScan software. You will then be able to get the full DTC and ForScan will point you in the right direction. Quote Link to comment Share on other sites More sharing options...
