AdBlock Warning
Looking at one of these but heard different opinions on the diesel particulate filters (dpf) any advice if I should go for one or no
DPFs are ok so long as they can regenerate, which involves around 20-30 minutes (in one go) driving at motorway speeds a month. They also need a regen fluid refil every 75000 miles. Failure to regen properly will eventually lead to needing a new DPF, which I believe is about £1000 at a Ford dealer.
...or, you can take it off, cut off the top, pull out the insides, weld in a pipe connecting the front and back which is the same diameter as your standard pipe, weld the top back on, and have the DPF deleted in the ECU.
In a month I usually do 2 trips to aberdeen and back which is about 128 miles each trip plus the usual trip into town so wasn't sure if dpf would clean itself out
The DPF on the diesel ST are a lot better designed than earlier versions as they are Euro6 spec.
The Euro4 spec needed Eolys fluid and the Euro5 had a tendency to not want to carry out a regen when needed.
The Euro6 DPF is easier to maintain and will cause far less problems and seeing as it will be on a ST you will be more likely to give it a bit of a boot on a motorway anyway ;) .
Put simply, GO FOR IT!!!.
Don't get put off a great car because of a minor thing.
I have a ST TDCI and really recomend it,as said don't be put off by the DPF
st2 I'll be picking but hard choice is colour partner doesn't like the yellow but I do so might have agree on some other colour lol
Oi Clive I like my stealth!
I have said before that the colour grew on me while I had a Stealth one for 3 days however it isn't striking enough to tempt me away from my blue one.
It does show the cars lines nicely but it is a bit flat, maybe if it had been a bit more sparkly I may have made a different choice.
Haha only playing with you fella, it's all personal opinion, otherwise this world would be a very boaring place. Tbh I like all the colours on the ST except Race Red.
My only thing with the Tangerine Scream is it says scratch me!
Totally agree.
Tangerine is very striking but just asks for a yob to apply his bail hostel key to it.
Mine only attracts attention from people who actually know about cars and are more likely to appreciate it rather than damage it.
I have had 3 local car clubs stick business cards under the wipers so far so must be drawing the right 'sort' .
