Ford Focus Mk2 DPF Error Code P2463 'DPF - Excessive Soot Accumulation'
My wheels were 16" Titanium multispokes and balanced fine, the wheel wobble was always there even immediately after new tyres & balance though.  I suspect the hubs were probably warped but it wasn't worth the cost of changing them until the bearings wore out...which they never did under my ownership.
I've also got a wheel wobble on the Golf.  I do have a dodgy wheel weight on the back though (stuck on with blutack as a temp fix 14 months ago! :laugh: ) and a slightly dented rim on the other side (doesn't lose air so I've just left it).  It's previously been in a front end impact though so the subframe may even be out of alignment.  I'm determined not to spend any money on it though...most people seem to put up with various vehicle faults so that's the approach I'm taking with this after all the money spent on the Focus' to try and make them 'perfect' lol.
  • Replies 76
  • Views 146.2k
  • Hi Guys (@TomsFocus, @Tdci-Peter & @Tizer), Thanks for all of your input so far! I think I'm going to send the DPF off to the DPF Cleaning Company (www.thedpfcleaningco.co.uk) and see if
  • Tdci-Peter
    Tdci-Peter
    Before changing the sensor, check the hoses from the DPF to the sensor. These are notorious for going brittle and cracking or breaking, which will give incorrect readings at the sensor.
  • Tdci-Peter
    Tdci-Peter
    From other reports, it it quite easy to replace the sensor. A basic old laptop running Windows 7 or even XP (I still use XP) should be quite cheap, Forscan is not a very demanding program in terms of
Did he say what the dpf pressure was?
Not sure what year your focus is but there was a wet system and dry system. If its wet check the additive tank is full.
check the dpf pressure pipes arnt cracked
Theres a few things to check but usually they require a new dpf.
