usmanzar Posted February 14, 2021 Share Posted February 14, 2021 Hi guys. My ford smax diesel 210 bhp has been cutting off power completely at high speed and under load I.e. engine turns off completely. Its been very scary as it has happened me over taking cars on fast lane with my kids at the back. Any one knows what could have been causing it? There is no engine management light on afterwards. Once pulled over. I put the car into park and it restarts like nothing happened. No fault codes were recorded. Quote Link to comment Share on other sites More sharing options...
Costi Posted February 14, 2021 Share Posted February 14, 2021 Hi Possible high pressure fuel pump can't keep up with fuel demand. Usually car must goes in limp mode, reduced power but not cutting off completley. After diagnostic should be an error code stored in memory. Is a spung in the high pressure fuel pump which somethimes snaps a coil and pump is not maintaining pressure. Quote Link to comment Share on other sites More sharing options...
usmanzar Posted February 24, 2021 Author Share Posted February 24, 2021 On 2/14/2021 at 11:51 PM, Costi said: Hi Possible high pressure fuel pump can't keep up with fuel demand. Usually car must goes in limp mode, reduced power but not cutting off completley. After diagnostic should be an error code stored in memory. Is a spung in the high pressure fuel pump which somethimes snaps a coil and pump is not maintaining pressure. I have had the codes now. Wondering if someone can explain exactly what is wrong with my car. 1 Quote Link to comment Share on other sites More sharing options...
usmanzar Posted February 24, 2021 Author Share Posted February 24, 2021 On 2/14/2021 at 11:51 PM, Costi said: Hi Possible high pressure fuel pump can't keep up with fuel demand. Usually car must goes in limp mode, reduced power but not cutting off completley. After diagnostic should be an error code stored in memory. Is a spung in the high pressure fuel pump which somethimes snaps a coil and pump is not maintaining pressure. Mine isn't going into limp mode. It simply cuts out. 1 Quote Link to comment Share on other sites More sharing options...
Meta55 Posted February 27, 2021 Share Posted February 27, 2021 The code seems to come up fuel pressure regulator if you google it. Think that’s one best left to a competent Mechanic. Quote Link to comment Share on other sites More sharing options...
Miroslavf Posted July 3, 2022 Share Posted July 3, 2022 Hello, I bought also 210hp S-max 2015 and it is doing the same think. 100km/h, 2700rpm and cut off engine. Need to stop, switch off engine and start again. P0087 stored in dtc. Fuel filter replaced, fuel regulator also. Pressure on the injectors is correct. No change after replacement of these parts. I assume, that fuel pressure sensor on the common rail is faulty. Have your fixed now? Thank you, Miroslav Franko Quote Link to comment Share on other sites More sharing options...
Craigo1986 Posted July 3, 2022 Share Posted July 3, 2022 Check the wiring that runs on the top of the engine as our 2.0l 210bhp one cuts out randomly when putting foot right down... lifted engine cover off and found it had been rubbing on engine cover and had 5 wires showing bear copper.... have now repaired them and touch wood the car has been fine and not cut out! We were getting codes of P02FA and P228C 1 Quote Link to comment Share on other sites More sharing options...
Miroslavf Posted July 4, 2022 Share Posted July 4, 2022 Hello, it looks like the cables are OK, no damage to them. It is strange for me, because with higher speed and more load it is running without issue. Just around 100km/h. Quote Link to comment Share on other sites More sharing options...
Miroslavf Posted July 4, 2022 Share Posted July 4, 2022 Hello, Pressure sensor on the common rail did not help also. Quote Link to comment Share on other sites More sharing options...
Miroslavf Posted July 17, 2022 Share Posted July 17, 2022 Hello, new fuel pump did not help. It looks like petrol instead of diesel was put in. It looks like whole fuel system is damaged. Metal debris also found inside. I have returned vehicle. Quote Link to comment Share on other sites More sharing options...
shez83 Posted April 12, 2023 Share Posted April 12, 2023 Hi, did you sort this problem? We are also getting this pro lem when towing caravan, so when the car is under load with caravan and car with children in it..... 🫣 1 Quote Link to comment Share on other sites More sharing options...
Toni S MAX Posted May 4, 2023 Share Posted May 4, 2023 On 4/12/2023 at 2:10 PM, shez83 said: Hi, did you sort this problem? We are also getting this pro lem when towing caravan, so when the car is under load with caravan and car with children in it..... 🫣 Hi, did you sort this problem? I have the same one Quote Link to comment Share on other sites More sharing options...
Toni S MAX Posted May 4, 2023 Share Posted May 4, 2023 On 2/24/2021 at 8:52 PM, usmanzar said: Mine isn't going into limp mode. It simply cuts out. Hi, did you sort this problem? Quote Link to comment Share on other sites More sharing options...
Ford Smax 2017 Vignale 210 Posted May 9, 2023 Share Posted May 9, 2023 On 2/14/2021 at 12:42 AM, usmanzar said: Hi guys. My ford smax diesel 210 bhp has been cutting off power completely at high speed and under load I.e. engine turns off completely. Its been very scary as it has happened me over taking cars on fast lane with my kids at the back. Any one knows what could have been causing it? There is no engine management light on afterwards. Once pulled over. I put the car into park and it restarts like nothing happened. No fault codes were recorded. Hi there, I hope you got this sorted? I have the same issue, with the same spec car. Contacted Ford Ho to see what their records show on this fault. Quote Link to comment Share on other sites More sharing options...
Toni S MAX Posted May 9, 2023 Share Posted May 9, 2023 Unfortunately no🙁 Quote Link to comment Share on other sites More sharing options...
Toni S MAX Posted May 9, 2023 Share Posted May 9, 2023 On 7/3/2022 at 1:16 PM, Craigo1986 said: Check the wiring that runs on the top of the engine as our 2.0l 210bhp one cuts out randomly when putting foot right down... lifted engine cover off and found it had been rubbing on engine cover and had 5 wires showing bear copper.... have now repaired them and touch wood the car has been fine and not cut out! We were getting codes of P02FA and P228C Can someone explain exactly where this cable connection is located.I've been looking for it for a long time today but i couldn't find it.Thanks Quote Link to comment Share on other sites More sharing options...
Craigo1986 Posted May 10, 2023 Share Posted May 10, 2023 Its the main loom that runs accross the top of the engine to the injectors.. if you look where the engine cover is the loom rubs on it on the left hand side as you look at it Quote Link to comment Share on other sites More sharing options...
Toni S MAX Posted May 10, 2023 Share Posted May 10, 2023 thanks mate,will check Quote Link to comment Share on other sites More sharing options...
Toni S MAX Posted May 10, 2023 Share Posted May 10, 2023 several times it puts me in very dangerous situations, it only happens when i accelerate fast on the freeway Quote Link to comment Share on other sites More sharing options...
GregX7 Posted May 12, 2023 Share Posted May 12, 2023 Colleague had similar problem on Mondeo 2.0 TDI, cutting out no faults found. Main dealer had the car in numerous times and could not diagnose the fault. Eventually traced to faulty injector that was overfuelling. Injectors replaced problem fixed. Quote Link to comment Share on other sites More sharing options...
shez83 Posted May 16, 2023 Share Posted May 16, 2023 On 5/4/2023 at 10:41 PM, Toni S MAX said: Hi, did you sort this problem? I have the same one Hi, no still have the problem, now happening more often 😔 have been told to get the injectors tested but that's approx £300 and then £1000 to replace which wouldn't be as bad if it would definitely fix the problem..... Quote Link to comment Share on other sites More sharing options...
kaagaa Posted January 5 Share Posted January 5 Hi. Have you solved the problem? I had this too with an 2015 2.0 tdci Galaxy. I replaced the gas tank fuel pump, but the P0087 code didnt disapeared. Quote Link to comment Share on other sites More sharing options...
Alexandar Posted Sunday at 08:26 PM Share Posted Sunday at 08:26 PM I bought a 2017 S-Max 2.0 SCTi second-hand. Passed full diagnostics in an authorized dealer. The first time it cut off on me was at a crossroads, it was super stressful, but nothing compared to when it did on the highway in the middle of the night with the whole family as the beams went out as well, and I was going 120km/h. But there's no rhyme or reason to when is going to happen. Going slow, going fast, accelerating, decelerating... even stopped. Start/stop system being off doesn't make a difference. It even did it while we were parked. Brough to local Ford dealer. Nothing... can't diagnose as it is sporadic and doesn't seem to leave relevant errors. I've never heard of a car doing this ever, even 20+ year old junkers... scary and disappointing. I will keep looking for a solution, but if anyone figures out some common fault, please do share... 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted Sunday at 09:44 PM Share Posted Sunday at 09:44 PM Do you have keyless start ? Quote Link to comment Share on other sites More sharing options...
Alexandar Posted 18 hours ago Share Posted 18 hours ago @unofix, yes, it's keyless Quote Link to comment Share on other sites More sharing options...
