stef123 Posted December 30, 2016 Share Posted December 30, 2016 2 hours ago, v530anh said: I bought a halfords Jack today low profile as i was to use on the pavement. Their axle stands we're min 33cm, so just had to raise the car high enough! Anyway once the wheel was off, I could clearly see the spring was broken, but it is broken at a very low level there is very little risk of it falling out. Sprayed wd40 and a little autosol around some rust and put the wheel back on. I have decided to leave it, and the spring seems good just a little rust at the bottom got the best of it. I can see it is easy to change the spring, just 2 bolts. But the rust on these nuts! I don't think the m.o.t guy will find out, unless he takes the wheel off. you are in for a surprise then! 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted December 30, 2016 Share Posted December 30, 2016 2 hours ago, dezwez said: If the spring is broken anywere they will fail your car and if it’s a call back to check If you have done the work and it fails you will have to have it re mot again full cost to you not quite true, in some circumstances you can pass a car with a broken spring. Quote Link to comment Share on other sites More sharing options...
v530anh Posted December 30, 2016 Author Share Posted December 30, 2016 The spring was broken before I passed the m.o.t. The m.o.t centre was not a garage. Then I went to trust Ford and they said not to show the health check, and wished me luck. ....then I had free recheck and passed. 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted December 30, 2016 Share Posted December 30, 2016 Where a coil spring is incomplete, cracked or fractured at an extreme end where the spring locates on the spring mount, it should only be rejected if: the function of the spring is impaired following jacking, the spring ends do not locate correctly when the vehicle is lowered into the normal running position without assistance These criteria should also be applied to springs that have been deliberately shortened or modified in order to lower the suspension. 1 Quote Link to comment Share on other sites More sharing options...
