bigshorty Posted November 3, 2015 Share Posted November 3, 2015 Hi All Noticed a bit of an issue lately with my Focus, and wondering if anyone has any ideas what could be going on. The car has done 106000 miles to date and all has been well up until the last few weeks. As I am driving along I've noticed a slight stutter / judder at steady speeds. The car starts fine, idles well, accelerates and decelerates without any problems, it only happens when the car is at steady speeds. Recently had oil and filter change, air filter change, cambelt done 20000 miles ago, doesn't overheat (although under the bonnet does seem quite hot after a longish run, even though the temp gauge always reads half way), and no error codes are coming up, so I'm wondering what could be causing the issue. If anyone has any advice or info on why this is happening and what to look out for, I would be grateful to hear from you. Many thanks in advance. Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted November 3, 2015 Share Posted November 3, 2015 When was the fuel filter last changed ? Quote Link to comment Share on other sites More sharing options...
bigshorty Posted November 3, 2015 Author Share Posted November 3, 2015 From my knowledge, and going through the paperwork, never! I was sort of thinking it was a fuel delivery problem somewhere. 1 Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted November 3, 2015 Share Posted November 3, 2015 Not a surprise . . I'd change the fuel filter asap 1 Quote Link to comment Share on other sites More sharing options...
bigshorty Posted November 3, 2015 Author Share Posted November 3, 2015 Ok. Will do that asap. Cheers for the help! Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted November 3, 2015 Share Posted November 3, 2015 No problem :) Quote Link to comment Share on other sites More sharing options...
cmozzer Posted November 3, 2015 Share Posted November 3, 2015 first change spark plugs , but its probably an ignition coil on the way out . just realized diesel , oops sorry 1 Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted November 3, 2015 Share Posted November 3, 2015 Spark plugs on a derv ???????? 1 Quote Link to comment Share on other sites More sharing options...
cmozzer Posted November 4, 2015 Share Posted November 4, 2015 as i stated , realised my mistake 1 Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted November 9, 2015 Share Posted November 9, 2015 go to kwik fit, I am sure they will convince you sparks exist on a diesel 3 Quote Link to comment Share on other sites More sharing options...
iantt Posted November 9, 2015 Share Posted November 9, 2015 go to kwik fit, I am sure they will convince you sparks exist on a diesel And convince you need nitrogen (or fresh air)in your tyres at extra cost 4 Quote Link to comment Share on other sites More sharing options...
Lenny Posted November 9, 2015 Share Posted November 9, 2015 go to kwik fit, I am sure they will convince you sparks exist on a diesel I wonder if QuickQuid and KwickFit are the same owner 😀 2 Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted November 9, 2015 Share Posted November 9, 2015 haha, they will try anything! 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted November 9, 2015 Share Posted November 9, 2015 .. Quote Link to comment Share on other sites More sharing options...
bigshorty Posted November 9, 2015 Author Share Posted November 9, 2015 Cheers for all the info Lenny. Informative stuff and some useful guides to go with. I have already done the fuel treatment, however used Archoil (think that's what it was), not the Xado stuff. Plenty of good reviews on the Archoil, and did notice an improvement in performance. Would you recommend Xado ahead of all other brands out there? Definitely, give the total flush a go, as for blanking the egr valve, I'll let my mechanic mate loose on that one, as well as the fuel filter. He doesn't work at Kwik Fit!!! 2 Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted November 9, 2015 Share Posted November 9, 2015 Archoil & Xado are the best products on the market i.m.o. & from personal experience 1 Quote Link to comment Share on other sites More sharing options...
supercmaxer Posted November 9, 2015 Share Posted November 9, 2015 Hi Lenny, I have fitted a blanking plate on egr but has the hole in it, I know the benefits of having a full blank but will it cause any damage to the egr? I've just had a new one fitted and don't fancy replacing it anytime soon. Where does the gases go if it's blanked off? 2 Quote Link to comment Share on other sites More sharing options...
Lenny Posted November 9, 2015 Share Posted November 9, 2015 .. 2 Quote Link to comment Share on other sites More sharing options...
supercmaxer Posted November 9, 2015 Share Posted November 9, 2015 Wow, didn't expect all that info. Nice one. I'll order a full blank and read guide lol. One question, do you happen to know where I can get info from regarding the vacuum on the anti shudder valve? I have no vacuum that closes the valve. Replaced the solenoid but still nothing. I need pipe work info as I have two pipes that aren't connected any where and unsure where they go 1 Quote Link to comment Share on other sites More sharing options...
supercmaxer Posted November 9, 2015 Share Posted November 9, 2015 No problem, I did see a thread similar to this vacuum problem before on a focus hatch, I'll find it tomorrow and insert link, includes pictures as far as I remember the guy had turbo failure and was left with some pipes and couldn't see where they went. I'm up at 5am for work so I'll find and link it tomorrow may help That might have been me lol, I had no turbo but that's fixed. Had faulty fuel pressure switch. Just have no vacuum on the same shudder valve. 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted November 10, 2015 Share Posted November 10, 2015 .. 1 Quote Link to comment Share on other sites More sharing options...
bigshorty Posted November 10, 2015 Author Share Posted November 10, 2015 More great info, cheers Lenny. Just one question, when do you think would be best to put the egr blanking plate on? Before or after doing the Xado oil treatment, or does it make no difference when its put on? Got a blanking plate on order, its definitely sounds like something worth doing for such a minimal cost. 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted November 10, 2015 Share Posted November 10, 2015 .. Quote Link to comment Share on other sites More sharing options...
