Stoney871 Posted March 2, 2017 Share Posted March 2, 2017 8 hours ago, Tdci-Peter said: Already done! The schematics are now stored on this site, with links to them a few replies back, here: @Stoney871 Clive: Could you use your Super Mod powers to edit the original post in this thread to point to the working links? Links updated. 1 1 Quote Link to comment Share on other sites More sharing options...
stepdey Posted March 28, 2017 Share Posted March 28, 2017 Thank you, much appreciated Quote Link to comment Share on other sites More sharing options...
vindi93 Posted July 30, 2017 Share Posted July 30, 2017 Anyone got the mk3.5 wiring yet Quote Link to comment Share on other sites More sharing options...
skyway20 Posted August 6, 2017 Share Posted August 6, 2017 Hi I'm new to this forum so hi. I have a question my diagnostic port popped in to the dash after trying to get my forscan to work (I still can't COM error) so I pulled the cover off and noticed a connector unplugged with the blue and purple wire cut and taped together anyone have any clue what this is or why it's like it. Thank Matt Ford focus1.8 tdci 08 Quote Link to comment Share on other sites More sharing options...
Tdci-Peter Posted August 6, 2017 Share Posted August 6, 2017 7 hours ago, skyway20 said: noticed a connector unplugged with the blue and purple wire cut and taped together It looks a bit like an after-market add-on to me, that was removed prior to sale. The lack of any stripes in the wire colours is a clue, very rarely will 5 single colour wires be in one Ford connector. I can not think of any standard equipment with a 5 pin connector in that area. COM port errors could be a driver missing or incompatible, or just possibly a dodgy ELM. If you are using Windows, locate Device Manager (via Control Panel, Administrative Tools, and Computer Management, possibly), and see if it says anything helpful. It should show a list of available COM ports, including ones simulated via USB or wireless. But also check there is 12v on the DLC ( diagnostic port) on pin 16. Some LEDs should light up on the ELM if there is 12v there. There should be 0v on pins 4 & 5 also. Some owners re-wire the DLC to prevent theft, then may forget to put it back right, or tell anyone when selling. Also there is a Fuse, F46 on a Mk2, F107 on a Mk2a, in the 12v supply to the DLC. 1 Quote Link to comment Share on other sites More sharing options...
skyway20 Posted August 6, 2017 Share Posted August 6, 2017 43 minutes ago, Tdci-Peter said: It looks a bit like an after-market add-on to me, that was removed prior to sale. The lack of any stripes in the wire colours is a clue, very rarely will 5 single colour wires be in one Ford connector. I can not think of any standard equipment with a 5 pin connector in that area. COM port errors could be a driver missing or incompatible, or just possibly a dodgy ELM. If you are using Windows, locate Device Manager (via Control Panel, Administrative Tools, and Computer Management, possibly), and see if it says anything helpful. It should show a list of available COM ports, including ones simulated via USB or wireless. But also check there is 12v on the DLC ( diagnostic port) on pin 16. Some LEDs should light up on the ELM if there is 12v there. There should be 0v on pins 4 & 5 also. Some owners re-wire the DLC to prevent theft, then may forget to put it back right, or tell anyone when selling. Also there is a Fuse, F46 on a Mk2, F107 on a Mk2a, in the 12v supply to the DLC. Hi thanks puts my mind at rest did think it looks a bit out of place. I think it's the ELM playing up my launch works fine. All I wanted to do was program new keys got more help from you them they guy i brought it off. Thanks 1 Quote Link to comment Share on other sites More sharing options...
Wojtek Posted October 8, 2017 Share Posted October 8, 2017 On 19.04.2013 at 11:46 PM, Preee said: A little gift , here are the PDF electrical wiring diagrams for the Ford Focus Focus Mk2/2.5 + ST PDF dated 2010 - Click Here Focus Mk3 PDF dated 2011 , not ST - Click Here Very usefull indeed if your trying to figure out additions to your car or find wiring Regards Preee Check out I think the links are swapped 1 Quote Link to comment Share on other sites More sharing options...
Tdci-Peter Posted October 8, 2017 Share Posted October 8, 2017 2 hours ago, Wojtek said: Check out I think the links are swapped Yup, that seems to be the case. 42086 is for the 2011 (mk3), and 42087 is for the Mk2/2a. The original files were "in the cloud", and evaporated as clouds invariably do . I uploaded copies to the site server in August 2016, and the original links were later updated. But somewhere along the way, they got reversed. A super-mod (eg @Stoney871) will be needed to correct the original links. It is well beyond my powers! Like with all the photobucket stuff, the moral is: Do not rely on any information stored in "the cloud"! Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted October 8, 2017 Share Posted October 8, 2017 The links have been corrected. 1 Quote Link to comment Share on other sites More sharing options...
tony01354 Posted October 11, 2017 Share Posted October 11, 2017 wow 132 pages of schematics ... excellent thanks Hi m8, does these schematics cover the mk3 focus st 2.0 tdciSent from my SM-G925F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Tdci-Peter Posted October 11, 2017 Share Posted October 11, 2017 6 hours ago, tony01354 said: does these schematics cover the mk3 focus st 2.0 tdci The 2.0TDCI is called DW10C in the drawings. But Preee did say "not ST" in his original post. How much difference there is, I do not know, but there must be a lot of the same wiring between ST and non-ST. Quote Link to comment Share on other sites More sharing options...
Dazzleguy Posted October 13, 2017 Share Posted October 13, 2017 Does anyone know where exactly this earth is located on the car? Thanks Quote Link to comment Share on other sites More sharing options...
ThaiFiesta Posted December 30, 2017 Share Posted December 30, 2017 On 25/05/2016 at 9:09 AM, Bannko said: Thinking about adding the ST clocks to my regular Focus In general i have no knowledge in wiring, just a guy who can make it work asked about my cars wiring schematics. So i was only not sure if i could provide him the one for MK3. Did you ever get this to work? Quote Link to comment Share on other sites More sharing options...
Yetello Posted December 31, 2017 Share Posted December 31, 2017 How is your Russian Language? https://www.drive2.ru/l/451264037246731091 It is possible but only on certain vehicles. In my MK3 1.6 Duratorque Titanium only Boost and oil Pressure are working with very tiny indications at the beginning of the scales on each dial. only 5 wires needed PWR (12vdc) Switched Illumination GND Can Bus High speed HIGH Can Bus High Speed LOW 2 Quote Link to comment Share on other sites More sharing options...
Singhpin Posted February 23, 2018 Share Posted February 23, 2018 On 19/04/2013 at 10:46 PM, Preee said: A little gift , here are the PDF electrical wiring diagrams for the Ford Focus Focus Mk2/2.5 + ST PDF dated 2010 - Click Here Focus Mk3 PDF dated 2011 , not ST - Click Here Very usefull indeed if your trying to figure out additions to your car or find wiring Regards Preee Focus 2011 Wiring.pdf entire_schematics_ph8m5t-70000-ad.pdf This is amazing. Thank you! Quote Link to comment Share on other sites More sharing options...
k_j_jacobs Posted March 18, 2018 Share Posted March 18, 2018 This is great anyone know how to aquire the 2009 model titanium wiring diragrams and drawings for Aircon? Quote Link to comment Share on other sites More sharing options...
alclot Posted December 28, 2018 Share Posted December 28, 2018 Hi mates. Amazing post! I have Ford Focus 1.6TDCi 110HP year 2006 with problems with PATS. I would like to match immo on bench. Can anybody help me how to wiring odometer, pcm and coil on bench to do that? On the photo you can show the units I would like to connect. Thanks a lot in advance 😉 Quote Link to comment Share on other sites More sharing options...
vindi93 Posted February 16, 2019 Share Posted February 16, 2019 Has anyone come across the m3.5 wiring diagram yet ? Quote Link to comment Share on other sites More sharing options...
PaulJ Posted August 23, 2019 Share Posted August 23, 2019 can somebody please repost the focus mk2/2.5 full schematics. the links have expired. specifically i need the egr wiring for the 6-pin electronic egr version. many thanks. Quote Link to comment Share on other sites More sharing options...
PaulJ Posted August 23, 2019 Share Posted August 23, 2019 sorry. just found the working link. 1 Quote Link to comment Share on other sites More sharing options...
Tdci-Peter Posted August 24, 2019 Share Posted August 24, 2019 10 hours ago, PaulJ said: just found the working link. I uploaded the current copies, as I had them on my hard disk from just before the links expired. Super Mod Clive (stoney871) updated the links, but it can be confusing as to which is the working one. I have to test them sometimes. Quote Link to comment Share on other sites More sharing options...
MCoop Posted September 19, 2019 Share Posted September 19, 2019 this is really handy however i am unsure what the small spade connector is there, it has a blue/brown wire on it, block conectors with it is my nonexistant parking aid and the other is for 12v Quote Link to comment Share on other sites More sharing options...
Micro Posted September 19, 2019 Share Posted September 19, 2019 4 minutes ago, MCoop said: this is really handy however i am unsure what the small spade connector is there, it has a blue/brown wire on it, block conectors with it is my nonexistant parking aid and the other is for 12v The orange one? Iirc it is a permanent live feed - i used it to power my rear power socket. Quote Link to comment Share on other sites More sharing options...
MCoop Posted September 22, 2019 Share Posted September 22, 2019 On 9/19/2019 at 5:52 PM, Micro said: The orange one? Iirc it is a permanent live feed - i used it to power my rear power socket. i know its permanant live, would my issue be the fuse for it being too small, currently 15A instead of 25A and i was asking what the blue/brown wire is if you know Quote Link to comment Share on other sites More sharing options...
Micro Posted September 23, 2019 Share Posted September 23, 2019 i know its permanant live, would my issue be the fuse for it being too small, currently 15A instead of 25A and i was asking what the blue/brown wire is if you knowYou can only pull what the wire can handle, there are lots of tables online that tell you the advised max current for a length of cable with a certain cross sectional area. Sent from my Pixel 3 using Tapatalk Quote Link to comment Share on other sites More sharing options...
