nickblackedge Posted August 16, 2018 Share Posted August 16, 2018 I'll have another go at down loading the files . Thanks kugaedge Quote Link to comment Share on other sites More sharing options...
Edge of Reason Posted August 16, 2018 Share Posted August 16, 2018 Well I appear to have been able to download the files for stick 2 (the One Drive one), but when I try to download the files for stick 1 (Googledrive version), my computer says preparing download, zipping 1 file, then nothing. I’ll try again. Quote Link to comment Share on other sites More sharing options...
Edge of Reason Posted August 16, 2018 Share Posted August 16, 2018 Well, what a marathon that was. After about 7 hours in all tonight, I think I now have all the files for sticks one and two. I’m not completely confident however and wondered if anyone who has successfully done their map update, would be good enough to list the files and folders that ‘should’ be on my sticks 1 and 2, so I can make certain before ruining my Satnav ! Thanks in advance. Ian Quote Link to comment Share on other sites More sharing options...
Edge of Reason Posted August 17, 2018 Share Posted August 17, 2018 Actually maybe fairer if I type what I have, if someone could please verify. Stick 1 contains 4 items..... SyncMyRide (folder) autoinstall.lst DONTINDX.MSA JR3T-14G421-BC-002.tar.gz The SyncMyRide folder above contains JR3T-14G424-BC_110777.tar.gz Stick 2 contains 2 items.... SyncMyRide (folder) autoinstall.lst The SyncMyRide folder above contains JR3T-14G422-BC.tar.gz Hopefully...... Quote Link to comment Share on other sites More sharing options...
schnipps Posted August 17, 2018 Share Posted August 17, 2018 Stick 1 move it so both .gz files are inside syncmyride folder, you don’t have any .gz on the root. Quote Link to comment Share on other sites More sharing options...
Edge of Reason Posted August 17, 2018 Share Posted August 17, 2018 @schnipps are the other files correct ? Quote Link to comment Share on other sites More sharing options...
Edge of Reason Posted August 17, 2018 Share Posted August 17, 2018 I sat in the car for 30 mins, trying to update using stick 1 with zilch occurring. I then re-checked my files against the autoinstall contents. One of my files on stick 1 is named JR3T-14G421-BC-002.tar.gz but the one referred to in the autoinstall is JR3T-14G421-BC.tar.gz so I’m assuming the autoinstall will not work as the file names don’t match. Do I need to install the file again or can I change the file name. The size of the file is 14,494,945 if this makes any odds. Confused.com Quote Link to comment Share on other sites More sharing options...
Hamster Posted August 17, 2018 Share Posted August 17, 2018 The '002' at the end of the file means it has been downloaded to the same location more than one. Just match the file names in the folder to those in the install files. I'm coming up to Scotland in a few weeks and i'll have a look if you want. H 1 Quote Link to comment Share on other sites More sharing options...
Edge of Reason Posted August 17, 2018 Share Posted August 17, 2018 Cheers Kev, but hopefully I’ll have it done. I’ll let you know though. Quote Link to comment Share on other sites More sharing options...
Edge of Reason Posted August 18, 2018 Share Posted August 18, 2018 Well I sat for 45 minutes today waiting on stick 1. Nothing happened. I’ve downloaded the files and created a fresh USB so will try again. Getting bored now. Might just buy a road atlas. Quote Link to comment Share on other sites More sharing options...
Edge of Reason Posted August 18, 2018 Share Posted August 18, 2018 SUCCESS ! At last, I have upgraded to F7 mapping. As I didn’t have USB sticks in the conventional sense, I was using SD cards with a USB adaptor and the card I was using for ‘Stick 1’ (Sandisk Extreme Pro 64gb SDHC) wasn’t liked by SYNC. I changed to a standard Sandisk 32gb SDHC card and the update went on. In fact within 5 seconds of inserting the USB, ‘Updating System Software...’ appeared at the top of the SYNC screen. The update for Stick 1 took 33 minutes. My card for Stick 2 was a Sandisk Ultra 32gb SDHC, which worked perfectly and the Stick 2 update took 20 minutes. As I’m in the Edinburgh area, I knew that the Queensferry Crossing, which opened a year ago and replaced the Forth Road Bridge, didn’t appear on the old map, so I immediately checked and it does appear on the new map, so no more driving on water for me. 😃 Thanks to @KugaEdge for the files, @simonb65 for troubleshooting and @Hamster for the offer of a home visit 👍. 1 Quote Link to comment Share on other sites More sharing options...
KugaEdge Posted August 18, 2018 Author Share Posted August 18, 2018 Glad you got there in the end Ian. I wish I could make this more foolproof for people but sadly given the limitations of free hosting sites and the difficulties of downloading such large files I don't think I can. Quote Link to comment Share on other sites More sharing options...
Edge of Reason Posted August 18, 2018 Share Posted August 18, 2018 I think you’ve done very well. I had difficulty in downloading the files initially, I couldn’t understand why one of my files had an incorrect name and then had an issue with the memory card used. I was ready to give up, then....bingo. Happy boy now. Incidentally, I now have various POIs on the map, that I hadn’t had previously, including roadworks (although the roadworks icon was about 1/4 mile out). Seems a bit more detail of surroundings in the map to me too. Either that or I’ve never studied it previously. Quote Link to comment Share on other sites More sharing options...
Loz1970 Posted August 19, 2018 Share Posted August 19, 2018 I've copied everything into my Mega account, hopefully you can get what you need from here if you're struggling with the links provided. I've not added or edited anything so, read all above for help. I'm not sure of their bandwidth restrictions, so good luck! Download as ZIP then use 7-Zip or your favourite archive util to extract. https://mega.nz/#F!bQEBQIoI!NSn0IdBYqfcdNFzIJLSw9w I will host for at least 6 months. 1 1 Quote Link to comment Share on other sites More sharing options...
simonb65 Posted August 20, 2018 Share Posted August 20, 2018 Hey! Finally got round to updating my own from EU4-14 to F7 ... Maps (1st stick) took around 45 mins, Voice (2nd Stick) took just over 20 mins. No issues. Fairly straight forward. Like @Edge of Reason, I used a USB-MicroSD card adapter with a Medion 32GB Micro SDHC card which I formatted to exFAT before copying the files onto it. Quote Link to comment Share on other sites More sharing options...
Alienburt Posted August 24, 2018 Share Posted August 24, 2018 Sorry for being thick - but do I need to unzip the files first before using - thanks Quote Link to comment Share on other sites More sharing options...
Edge of Reason Posted August 24, 2018 Share Posted August 24, 2018 Not thick. A perfectly reasonable question. Yes is the answer. Anything that arrives zipped, needs to be unzipped. I created a Stick 1 folder and Stick 2 folder on my desktop and anything that was zipped, I unzipped into the appropriate folder. Just remember when you copy the files onto your USB drives, only copy the contents to the root of the USB and not the folder you saved them in. You could unzip straight onto the USB if you prefer, but for me, one of the files went into the wrong place. Quote Link to comment Share on other sites More sharing options...
Alienburt Posted August 25, 2018 Share Posted August 25, 2018 Thanks Ian - much appreciated In my Syncmyride folder I have 2 files - JR3T-14G421 and JR3T-14G424. Outside the folder I have 2 files - autoinstall.lst and Dontindx.msa Is this correct? Regards Quote Link to comment Share on other sites More sharing options...
Loz1970 Posted August 25, 2018 Share Posted August 25, 2018 Remember guys, the SYNC 3 system is sensitive to types of USB drives as well, so if you're waiting ages for it to start and nothing happens within say 5 mins, it may not like your USB drive, I've got lots of them as I work in IT, and it wouldn't work with my LEXAR USB 3.0 drives, they flash and look like they're being accessed, but nothing would happen. Tried a different brand with the same files, boom, the upgrade started. Best way to test if your USB drive is good for the upgrade, see if you can play some music from it first, format it, copy a few MP3's. If they play, your USB drive will work for the upgrade, if it doesn't play, then try another drive. 1 Quote Link to comment Share on other sites More sharing options...
Edge of Reason Posted August 25, 2018 Share Posted August 25, 2018 9 hours ago, Alienburt said: Thanks Ian - much appreciated In my Syncmyride folder I have 2 files - JR3T-14G421 and JR3T-14G424. Outside the folder I have 2 files - autoinstall.lst and Dontindx.msa Is this correct? Regards Yes that’s right for Stick 1. Stick 2 has similar autoinstall.lst and DONTINDX.msa files outside the Sync My Ride folder with JR3T-14G422 inside the folder. If the DONTINDX file doesn’t go onto stick 2, just copy the one from stick 1, it’s just a file to prevent Sync trying to index the contents of the USB. Quote Link to comment Share on other sites More sharing options...
Ryan McCombie Posted August 27, 2018 Share Posted August 27, 2018 Any chance you could make the sync 3 18025 files available? Can't seem to find them anywhere.. On a side note: the f7 maps worked fine even on sync 3 version 17276 1 Quote Link to comment Share on other sites More sharing options...
Edge of Reason Posted August 27, 2018 Share Posted August 27, 2018 The F7 maps will work on any Sync 3 version 3 car. The 18025 isn’t crucial. 1 Quote Link to comment Share on other sites More sharing options...
simonb65 Posted August 27, 2018 Share Posted August 27, 2018 I know you've now done it Ryan (from your Facebook posts), but for the others, If you can't get any joy (or aren't offered an update) from the Sync Update page, to update from v2.0 or v2.3 to v3.0, at ... https://www.ford.co.uk/owner/resources-and-support/sync-bluetooth/update#/ ... you can download the v3.0 (build 18025) update from ... https://fc.nf/sync330eunav Quote Link to comment Share on other sites More sharing options...
Alienburt Posted August 29, 2018 Share Posted August 29, 2018 Have tried with a couple of usb sticks but the car didn't accept them - so I bought a new 32gb sandisc usb 2.0 and tried again. The stick is recognised but I get the message LST_ERR05. Anybody any ideas please - Thanks Quote Link to comment Share on other sites More sharing options...
KugaEdge Posted August 29, 2018 Author Share Posted August 29, 2018 15 minutes ago, Alienburt said: Have tried with a couple of usb sticks but the car didn't accept them - so I bought a new 32gb sandisc usb 2.0 and tried again. The stick is recognised but I get the message LST_ERR05. Anybody any ideas please - Thanks Have you checked that you have all the correct files on the stick (the file list is detailed earlier in the post)? Have you done the upgrade of the Sync version first? Quote Link to comment Share on other sites More sharing options...
