Scottyghia Posted May 31, 2021 Share Posted May 31, 2021 Site says my maps are up to date but the Sync 3 has an update. 900mb I thunk it said. 🤔 Quote Link to comment Share on other sites More sharing options...
anon Posted May 31, 2021 Share Posted May 31, 2021 A 900 MB update to Sync3 probably prepares your car for the map upgrade. What version number is your current Sync and what version maps are you running? Quote Link to comment Share on other sites More sharing options...
Scottyghia Posted May 31, 2021 Share Posted May 31, 2021 Car is a Dec 2020 model. 3.4 build 19274 Not sure how to check map version. Quote Link to comment Share on other sites More sharing options...
anon Posted May 31, 2021 Share Posted May 31, 2021 Current Sync version is 20120. Install that and you should be prompted for the F10 maps if they are not installed already Quote Link to comment Share on other sites More sharing options...
Scottyghia Posted May 31, 2021 Share Posted May 31, 2021 Will do, cheers. Quote Link to comment Share on other sites More sharing options...
colinmcg71 Posted May 31, 2021 Author Share Posted May 31, 2021 5 hours ago, Chainsawcharlie said: Having problems with my version 10 maps update. Tried the download twice which all happens OK to my Windows PC Unzip it to a USB with at least 32gb capacity, formatted to exfat as instructions say All files go to root of the zip. I already did the sync 3 update today no problem. But now when I put usb into car after starting the engine get these messages. 1) Usb recognised 2) Software update 3) Indexing 4) sure you want to update, dont interupt..blah blah blah 5) Lic 001 ERR Contact some ford support number! Happened twice now with 2 downloads, and 2 different usb sticks. Anyone any ideas please Cheers Steve Hi Steve, The correct license file for EU F10 maps is 1U5T-14G424-BK Have a look inside your SyncMyRide folder and see if that file is present. Then open up the autoinstall file in notepad and make sure it is listed for install. Let is know how you get on Cheers Col Quote Link to comment Share on other sites More sharing options...
BrynS Posted June 1, 2021 Share Posted June 1, 2021 11 hours ago, anon said: Not at all. My nav works just fine. People who haven't the wit to even try though are not worth helping, don't you agree? Witless.. haven’t been called that for a while 😋 I think updating my nav is not at the top of my ‘to do’ list , and up to now not needed to get a flash drive to accompany my iPad for anything else in my life , and I’ve managed just fine thanks Quote Link to comment Share on other sites More sharing options...
BrynS Posted June 1, 2021 Share Posted June 1, 2021 11 hours ago, Chainsawcharlie said: Bryn, This maybe what you want mate, check which ipad model you have before ordering as they changed their plug size fairly recently https://www.amazon.co.uk/dp/B07ZP7F7J5/ref=cm_sw_r_cp_apa_glt_fabc_NCG2H9C4K4ZXNFA1HZE8?_encoding=UTF8&psc=1 Thanks for that 👍 I’ll have to get around to it at some stage Quote Link to comment Share on other sites More sharing options...
Guest Posted June 1, 2021 Share Posted June 1, 2021 . Quote Link to comment Share on other sites More sharing options...
colinmcg71 Posted June 1, 2021 Author Share Posted June 1, 2021 29 minutes ago, Chainsawcharlie said: Hi Colin, Just checked in syncmyride and all i see are zipped tar.gz files, several but not the 1U5T-14G424-BK one Also checked the autoinstall.lst no entry there of 1U5T-14G424-BK Cheers Steve That will definitely be the problem then. The complete list should be: Maps 1U5T-14G421-BAH.TAR.GZ 1U5T-14G421-BBH.TAR.GZ 1U5T-14G421-BCH.TAR.GZ 1U5T-14G421-BDH.TAR.GZ 1U5T-14G421-BEH.TAR.GZ 1U5T-14G421-BFH.TAR.GZ 1U5T-14G421-BGH.TAR.GZ 1U5T-14G421-BHH.TAR.GZ Navigation Voice 4U5T-14G422-BAF.TAR.GZ 4U5T-14G422-BBF.TAR.GZ 4U5T-14G422-BCF.TAR.GZ 4U5T-14G422-BDF.TAR.GZ Map License 1U5T-14G424-BK.TAR.GZ Here is a direct link to the map license file from Ford. You will have to rename it to remove the numbers between BK and TAR. After that you could edit the autoinstall file to include the license file. Make it item 1 in the first section of the install. Quote Link to comment Share on other sites More sharing options...
colinmcg71 Posted June 1, 2021 Author Share Posted June 1, 2021 4 minutes ago, Chainsawcharlie said: Thanks Col, I've been in touch with Ford and sent them all the info, will let you know what happens mate. Thanks for all your helpful advice, it makes perfect sense. Cheers, Steve No problem, hope they get it sorted out for you. Quote Link to comment Share on other sites More sharing options...
Scottyghia Posted June 1, 2021 Share Posted June 1, 2021 Updated to 20120 which went smoothly. Checked the map version and it says F8. The Ford site said my maps were up to date. 🙄 Quote Link to comment Share on other sites More sharing options...
Aldridge Andy Posted June 1, 2021 Share Posted June 1, 2021 I’m guessing that this update is only for MY2019.5 onwards? My 2018 Fiesta Titanium has no new updates offered on the Ford Sync3 website. I currently have F9 maps and Sync 3.0 firmware build 20204 Quote Link to comment Share on other sites More sharing options...
colinmcg71 Posted June 1, 2021 Author Share Posted June 1, 2021 1 hour ago, Chainsawcharlie said: Hi Col, just noticed your link at foot of your post, so regarding adding the licence text.... you say make it first item, but what will happen to the line of text already in as item 1 "item1 = 1U5T-14G421-BCH" do I simply add my licence line above that and have 2 item 1's? Also each entry has an accompanying line called open, do I need to add this too to my file? Thanks mate for your great help so far Sorry, I wasn't very clear there. You would add the item1 and open1 lines for the license file then bump the remaining item and open lines up by one. It would end up looking like this: Quote Link to comment Share on other sites More sharing options...
colinmcg71 Posted June 1, 2021 Author Share Posted June 1, 2021 12 minutes ago, Chainsawcharlie said: Ahhh great Colin, that makes sense. Thanks very much for the time you've kindly given to helping....I owe you one mate. No problem at all 👍🏼 Quote Link to comment Share on other sites More sharing options...
colinmcg71 Posted June 1, 2021 Author Share Posted June 1, 2021 14 minutes ago, Chainsawcharlie said: Thats strange mate, After looking at your text file, mine seems quite a bit different. See below. Yeah, that's quite different. From your screenshot not only is the license file missing but the first map package (1U5T-14G421-BAH) is too. No wonder the install won't progress. The F9 install list looked like this: It might be worth waiting to see what Ford come back to you with or you could try downloading the maps again. Quote Link to comment Share on other sites More sharing options...
colinmcg71 Posted June 1, 2021 Author Share Posted June 1, 2021 @Chainsawcharlie Here is the first map file (BAH) from Ford servers and this is how the correct autoinstall file should look: Quote Link to comment Share on other sites More sharing options...
colinmcg71 Posted June 1, 2021 Author Share Posted June 1, 2021 1 minute ago, Chainsawcharlie said: Thanks Col, yes its very odd. Never had problems with previous installers, and my background before retiring was software, so not sure where all this is going wrong. I've downloaded about 5 times now even after resubmitting log files and even interegator but no joy. Thanks bud 🙂 No worries, looks like it’s just going to be a case of waiting till Ford sort it out. Quote Link to comment Share on other sites More sharing options...
